Did i buy a fake ? Shell experts please shime in
hi! thought i should bump this thread since it's fairly related. i just bought 3 cans of shell helix ultra 5w40 for dirt cheap (22€/ud) on a fairly legit online shop. thing is, i opened one of them and the only seal is like the one a watter bottle would have. you only hear a "click" and that's it, it doesn't have that metallic adhesive looking thing that you usually have to peel. is it legit?
That was my typical experience with Shell. Sorry, that's all I can say, they don't have the aluminum foil like other brands can have.
Neither does Pennzoil unless it’s changed. I once got used motor oil purchased at Walmart. People were also stealing the codes under the caps and getting rewards/rebates. I listen for the “crack” when the cap is twisted, making note of the resistance to open.
Hmm so we have mixed results now, some say their shell came with the adhesive seal while others did not…
Could you specify the market? They probably do different things, Malaysia had serious problems with counterfeit shell so they incorporated a hidden QR code which tells you if it’s original or not, this, afaik is not done in Europe (which I’m from)
If that turns out to be real then it’s a huge embarrassment to Shell for letting stuff like that slip through. If they can’t get the spelling right then what else are they slacking off on?
The 5 quart container lids/seals. Regularly leak and the tamper-proof ring works about half the time.
The Shell 5L bottles i've purchased here in Spain did not have any aluminium foil.
Interesting
The last time I bought Shell it was 5w40 HX8 and I am fairly certain that had the foil seals.
Going to have to dig out the bottle and double check now😂😂
Maybe they have different pack for different markets
Though I would be inclined to think there is certainly the possibility that it’s a knock off, lots of fake car parts coming out of Turkey in recent years, wouldn’t surprise me if they have moved to doing oil aswell
VOA is likely the only way to be 💯 sure
bcs, you are from Europe US users cant help you if you think that there are different packages and seals which i doubt.google then can be your guide to your solution.
uk,europe. at 2.21 opens a fresh oil ,has no seal.
or
https://support.shell.my/hc/en-my/a...if-the-Shell-Lubricant-I-purchased-is-genuine
and also you can email opieoils.uk to tell you about it,they are experts.
that's very correct, Shell have also very poor quality on their packages in EU, and they tend to leak sometimes. ExxonMobil have best packages in my opinion
