Developing Oil Life Calculator, see inside.
OP, I have an Idea. Make a simple website, put calculator there, add some ads on it and make some money
Easier for us to go there and try whole stash of various oil, that most have,and apply to all the cars they want.
More than 2000 view just from BITOG i little over than a day, not bad.
This is a brilliant idea! Thanks
Originally Posted By: randomhero439
^^Well im impressed! The corrected TBN that your provided makes it 8255 miles or 9 months. Factoring in the bypass setup you have, i get 11017 or 13 months, but im assuming you could go longer than that.
I will be testing again at 15K. Forgot to add that I am nearing two years on this fill righ tnow. At 15K, I will likely be past 2.5 years and nearing three.
So, are you going to let the cat out of the bag and describe your system?
Here are two delivery trucks at my work...
2003 Ford E250 4.2L V6 240k miles - Valvoline 5w20 conventional
- no towing, see's up to a 1,500lbs load on a regular basis, kept in a heated warehouse overnight
2004 Toyota Tacoma Xtracab 2.4L I4 (automatic) 150k miles - Valvoline 5w30 conventional
- no towing, see's up to a 700lbs load on a regular basis, kept in a heated warehouse overnight
The Valvoline used in these two is from the instant oil change shops, I'm not sure how their regular bulk oil compares to their Valvoline conventional, you may know more than I do...
Try this one:
1967 VW Beetle, Rotella T6 5w-40 CJ4/SM
If it makes a difference, the engine is now 2276cc, fuel injected, uses a spin on filter, and has a deep sump giving it a total capacity of about 4 quarts and change.
Originally Posted By: LeakySeals
Random,
What about replenishment? Would think that should have some impact on OCI?
My calculator says for a typical conventional oil, replenishing 1qt would benefit about 1000 miles.
Im gonna give you a range for these vehicles since im not show how the loads will affect it.
Ford: 3382-4960 miles or 4-6 months
Toyota: 4321-6410 miles or 5-7 months
Originally Posted By: striker456
Thanks for the reply. Pretty awesome.
How about 60% TGMO 0w20 and 40% Mobil 1 0w40 blend on my 2005 Sebring 2.7L?
7883 miles or 10 months
Originally Posted By: MinamiKotaro
Try this one:
Not sure how the air cooled engine will affect oil temps, so im gonna give you a range.
5151-7705 miles or 7-10 months
Thanks for doing this - it's been fascinating to watch.
After doing the xB, I'll have to ask you to do the Ody now.
2001 Honda Odyssey EX
3.5 L J35A1
Mobil Super High Mileage 5w30
3.5 L J35A1
4884 miles or 5 months
Originally Posted By: vwGLI
interesting!
mine: 2006 VW Jetta GLI 2.0TFSI
Castrol EDGE SYNTEC 5w40
how about Mobil 1 0w40? I want to know it too. Thanks!
Syntec: 7295 miles or 9 months
Mobil 1: 8378 miles or 11 months
thanks dude
may i ask~ what will be the longest-lasting xW40 oil? and how long
3.5 L J35A1
Interesting. We were looking at 5000 miles/4 months for that.
interesting!
thanks dude
Mobil 1 0w-40. Also for every quart of make-up oil you add. Extend your OCI by 1710 miles on Mobil 1 0w-40. Just make sure your filter is adequate.
Originally Posted By: HTSS_TR
2000 Mercedes E430 4.3L V8, Mobil 1 0W40 SM
2004 Honda S2000 2.2L I4, Pennzoil Ultra 0W20 SM
1994 Lexus LS400 4.0L V8, Valvoline Synpower 5W30 SM
Mercedes: 12686 miles or 16 months
Honda: 13428 miles or 17 months Lexus: 7609 miles or 10 months
Assumes decent driving conditions. Got any used oil analysis for these?
No used oil analysis for any car.
The Mercedes is spot on mileage, I change oil once a year around 12k miles +/- 500 miles.
The Honda is changed once a year too at around 5k miles, I may extend it to 2 years at around 10k miles.
The Lexus is once a year at around 13-14k miles.
Only Lexus is top off about 1 quart in 1 year, others didn't have to add any oil.
Your calculator seems to be accurate for some engines and too conservative for others.
The Pennzoil Ultra 5w-20 SM has a massive TBN of 13.0.
For the Lexus, the quart of make-up oil gives me 9100 miles or 12 months. While Synpower SM has a TBN of 8.5.
2006 Pontiac Grand Prix GT 3.8 S/C
Pennzoil Ultra 5W30 API SN
and if you don't mind...
2006 Dodge Magnum R/T AWD 5.7 HEMI
Valvoline Synpower 10W30 API SN
Thanks so much randomhero439!
Pontiac: 4998 miles or 6 months Dodge: 8960 miles or 11 months
Originally Posted By: Clevy
I'll bite.
All vehicles in my sig. Lets say the mustang is getting a 50/50 mix of AFE 0w-20/Mobil 1 0w-40 or Pennzoil Platinum 5w-20/Mobil 1 0w-40 and oil cooler,7 quarts.
Same thing for the dodge 5.7 6 quarts
If you can make the Harley compute how about rotella t 15w40 3 quarts
Could you run them with PYB5w30, Quaker State Ultimate Durability 5w30,RP euro 5w-40,liqui-moly 0w-40,red line 5w-40. All the 40 grades are going to be mixed 50/50 with Pennzoil Platinum 5w-20. Does that complicate things,if it does just run em regular.
And post your equation. It's pretty cool that your getting this so close.
Thank you
Yeah most of what your doing complicates things haha.
Mustang on Mobil 1 0w-20/0w-40: 10115 or 13 months Dodge truck: 9341 miles or 12 months
Harley: Ill give you a range 4775-6262 miles or 5-7 months
Nice.
Thank you very much.
Originally Posted By: tinmanSC
What's the diff in mileage for a Lexus GS300 on 5w30 Valvoline Conventional, Synpower, Pennzoil Platinum, and Ultra?
VWB: 4834 or 5 months
Synpower & PP: 8058 or 10 months PU: 10572 or 13 months
