Tom NJ
$100 Site Donor 2026
Density is also used for converting between volume and weight for export shipping purposes. In the USA oil is usually sold by volume (gallons) but in many parts of the world it is sold by weight (metric tons).
With all the hype around non VII containing engine oils I’m surprised that the topic of non VS Newtonian fluids hasn’t been discussed.After reading all of the responses I’m still confused as to why the oil companies think that the average buyer cares about the density. People want to know the viscosity and the HTHS but I can’t see any reason why people would care that much about the density of different oils. Nobody here is saying they chose a particular oil because of its density valueIt seems like it’s something that should be in the SDS or somewhere else regarding the shipping aspect of the product but not in the technical data section. I hate that most manufacturers are making it harder to find the HTHS of their oils (but yet tell us the density!)
Actually that is Specific Gravity. Density is mass per unit volume.I believe it’s density compared to water.
Bingo. dynamicViscosity = density x kinematicViscosity
For a given KV, increasing density increases DV. Red Line and some other oils with quite a bit of esters are denser than most. Higher viscosity oils tend to be denser, if VII concentration is held constant. Kinematic viscosity matters when it drains down under the force of gravity. As you said, mostly it is dynamic viscosity that matters in an engine. The density variations of motor oils are not very large though. Plus or minus a few percent would contain the vast majority.
This article is really good. https://www.machinerylubrication.com/Read/294/absolute-kinematic-viscosity
At what temperature?
Change the temperature of the water, oil, etc even just 0.1 Centigrade, and the weight changes per 1000 liters.
But you said above that the weight changes per 1000 liters if the temperature changes, then later say if the temperature changes the weight remains the same. Conflicting statements. The latter is correct, a change in temperature does not change the weight, but it does change the volume and hence the density (ie, weight per volume)I literally own, and drive fuel trucks.
If i put 46,000 liters of gas in the trailer when its warm, and park it outside overnight at 25 below, it has shrunk in volume in the trailer, bu the weight remains the same
I've used the density specs for converting cSt to cP and vice versa, and as an input on pressure drop calculations (fluid dynamics calcs). Plus other people in industry may need to know the density for some kind of engineering calculation.After reading all of the responses I’m still confused as to why the oil companies think that the average buyer cares about the density. People want to know the viscosity and the HTHS but I can’t see any reason why people would care that much about the density of different oils.
Have a look at ASTM D4052I've used the density specs for converting cSt to cP and vice versa, and as an input on pressure drop calculations (fluid dynamics calcs). Plus other people in industry may need to know the density for some kind of engineering calculation.
Mass, and therefore weight doesn't change with temperature. Density changes with temperature because volume can change with temperature.Which is a change in weight per 1000 liters.
Cannot have 1 without the other.
If i put 46000 liters of gas in a trailer on a cold morning, then drive it 10 hours somewhere in the heat and blazing sunshine, it has expanded in the trailer, but the fuels weight remains the same.
Mass, and therefore weight doesn't change with temperature. Density changes with temperature because volume can change with temperature. What you said below is correct, but what you said before that wight changes with temperature was not correct. You are stating conflicting responses.
Do some research and prove it to yourself.Your so sure that you are correct...lets just pretend you are to stop this.
Your right okay....happy now?
Weight doesn’t change with temperature just as mass doesn’t either. The example of an overflowing container is a silly example.Your so sure that you are correct...lets just pretend you are to stop this.
