Delo 400 15w40 on mustang ?
MS
just wonder if delo 400 15w/40 is gasoline engine approve ? I have oil burn or something I dont know, but im current using mobil delva 15w40 and it reduce alot oil burn, im thinking switch to delo 400 cause alot peoples here seem like it. thanks
Mustang 4.6L
I would not use an oil that thick in any Ford 4.6 V8.
If I were you, I would put a PCV catch can in your PCV line. My car (96 CVPI) was using a lot of oil, and it was going through the PCV system.
Don't own one, but I've read here a ton of times that the Ford 4.6 V-8 don't like oil much thicker than 5W-20. 15w40 is way, way to thick for that engine...think you'll find it will 'liven up' and run much better on a 20 or 30-weight oil....
Personally, I like Delo over Delvac, but they're both quality oils. 5W20 or 5W30 are probably more ideal, but your 4.6L will be fine on 15W40. You may see some reduced fuel economy. There are plenty of fleet service Ford 4.6L/5.4L/6.8L engines running on 15W40.
