Data recovery from a computer that won't boot up?
USA
I know somebody who has a computer that will not boot up, but would like to recover pictures and files from the hard drive. Can this be accomplished by a novice?
Easiest way is to take the hard drive out and connect it as a Slave on another computer or put it into an External USB drive enclosure and plug it into your computer via USB and recover his data for him.
Exactly. Google how to take ownership of a file or folder (so you can access folders from another computer). Then
If it's really bad, and the data very high value or irreplaceable, then send the HDD here:
http://www.drivesaversdatarecovery.com/
But be prepared to pay heavily.
Be careful if your friend doesn't know what he's doing. The wrong steps can bugger up the data beyond recovery. Some malicious code can execute wipes and data destruction if you make the wrong move.
Otherwise, if it's just the routinely messed up OS, mount it as an external or internal slave drive, and as long as the file system fits the host, another system will pick up the data.
I'd passively AV/ASW scan the suspect HDD before pulling anything off of it, though.
Wonder if someone could just boot off of a Linux Live CD like Ubuntu and copy the pictures and files, etc., to an External USB Hard Drive?
Have never tried it but it could be a possibility.
Good suggestion, I've used a Knoppix Live CD to recover files from a system that won't boot, worked just fine.
