Scrapping Desktop - How To Safeguard Data?
I smash up the hard drives, bend up the discs and take the magnets. :) Those things are powerful. At one time I thought would be good to put one on the oil filter but forgot all about it and they are on the side of my tool box right now.
Do what they do at RAF Fylingdales when they want to destroy classified hard drives: Throw it into a vat of 200 tons of molten steel.
I remember there's a software the can write random data on every sector to dilute the residual prior magnetic field on the disk, and after 6 passes the previous data would be diluted into background noise (so people with electron microscope can't extract the data off it). This should be sufficient for non military grade data, no need to drill holes and the drive can be used for backup or off premise disaster recovery. Forgot the name of this software.
SSD would need another way to do it without wasting the finite erase and program cycles. There is usually a trim command to mark everything as ready for erase and you lose the FTL info and scrambler key (and maybe other keys on top of that), most likely the SSD manufacturer has a tool to do it fast and simple, as long as you are not storing military grade data on it.
  • Like
Reactions: Pew
If one had a chop saw, would cutting it in half destroy the data?
From casual user yes. If you have the will you can use an electron microscope to pick up the magnetic field off a broken platter to reconstruct a large portion of the data. That's why military always grind up something to dust or melt things down to metal.
Most civilians don't have something that worth the effort.
Acronis does that:
I used to take the magnets out first then hit them with a hammer. Recent magnets are useful but really old drives had very strong magnets. I have half a dozen magnets stuck on the metal tins in my workshop.
AFAIK, glass plates had a fairly short run on 3.5" desktop hard drives-I think only IBM/Hitachi did it for a few years in the early 2000s(some of the early Deskstars-and part of what gave them the "Deathstar" name). It's a lot more common on laptop(2.5") drives.
The Deathstar name was well deserved! I built a lot of PCs at that time and those had a sky high failure rate.
