Description of the problem and steps taken so far, then questions below.
I have an old Windows 10-based PC acting as a file server. Twice now, after it has been on for a few days, I've seen the HD access LED stuck on. In Explorer, one of the hard drives looked like it was half-disconnected; it had a volume name and drive letter, but no numbers for free/total capacity. The system was responsive until I tried to access that drive, at which point Explorer hung and I couldn't shut down or restart except with the power button. After restart, it was absolutely fine for a few days. All hard drives worked. Thought the problem was a fluke until it happened the second time.
The problematic hard drive is one of two identical Seagate Ironwolf drives connected via the motherboard's Marvell 88SE9172 chip. The other drive – again, same model, same controller – has yet to miss a beat.
I plugged the problematic hard drive into an external enclosure last night and everything seems fine so far. Chkdsk found no file system issues and no bad sectors. Virus scan (Webroot SecureAnywhere CE) found nothing.
I've already replaced the hard drive with a spare and updated the drivers for the Marvell controller (it had been using the generic driver). I plan to restore all the data from backups and move on. But ideally I'd like to know more about what may have happened.
Questions:
1. Is it possible that the hard drive is defective in a way that shows up only when connected via the onboard controller but not when connected to the external enclosure? If so, how can I check? The drive is still under warranty.
2. What other hardware/software problems are worth looking for at this point?
3. Can I trust the integrity of the data on that drive, so that I can copy everything directly from it to the new drive? Or does it make sense to download everything from cloud storage?
TIA!
Questions:
TIA!
