5 53' Stude Joined Mar 12, 2015 Messages 36,495 Location In the shop Dec 4, 2022 #21 OVERKILL: expanding on this; could water be a primary cooling and possible water/sodium concentrate be used as alternate/backup or….? Thank You
OVERKILL $100 Site Donor 2021 Thread starter Joined Apr 28, 2008 Messages 63,450 Location Ontario, Canada Dec 4, 2022 #22 53' Stude said: OVERKILL: expanding on this; could water be a primary cooling and possible water/sodium concentrate be used as alternate/backup or….? Thank You Click to expand... Doubtful that this would be viable as the added complexity would probably kill it. More likely would be the use of passive sinks to earth or air for passive cooling in the event of primary cooling failure.
