My oil is usually caramel colored on the dipstick, pull the drain plug it’s jet black
I have noticed that any car with HPL engine oil gets dark very, very quickly. It is the only brand where I have noticed this.I don’t know if I buy that. A diesel engine I agree, but a gasoline engine, not really.
Jet black oil probably means a lot of soot, like in a diesel engine. However unlike the diesel engines where the diesel oil is specifically formulated to deal with soot, I don’t think PCMO oils can do the same.
I would keep no more than 5k ocis, maybe even 3k if the oil gets diesel black this soon IMO.
That's my nice way of saying that I'm not going to elaborate on my experience with Quaker State. What you don't know won't hurt you.Sure, but that doesn’t apply here.
A good choice indeed. On past advice from Overkill , Kschachn and a few others at BITOG, I changed from Blackstone to Oil Analyzers Polaris labs. I buy the prepaid postage kits thru an Amsoil website. Oil Analyzers are quick to respond and give very clear and easy to follow reports. You can feel a lot better about the fuel % in your report from Oil Analyzers because they use the gas chromatigraph mass spectrometers unlike Blackstone who does not. The Blackstone fuel % is simply as good as a guess minus the use of a GC meters. When I first caught wind of all this on BITOG I thought it was a lot of over the top hype, apples vs oranges until I used both labs and learned the actual differences. It is wild to think a lab (Blackstone) can charge folks for these type of samples and simply not use a GC meter. Especially since fuel , is being one of the many results automotive folks want to know. The easily available, just about everywhere , GC meters are in just about every lab I have heard of or been to or even used on the job. Maybe it is all just another one of those "up-sell" type of things we all see from time to time? Just like for instance some will ask you to pay extra $$ to have your TAN or the TBN results included in your reports.Oil Analyzers would be my top choice for lab results. Overkill has used them along with some others for accurate fuel dilution results.
I've noticed the oil is much lighter when hot than cold.
That's a great way to participate in a forum that's set up to share information and experiences.That's my nice way of saying that I'm not going to elaborate on my experience with Quaker State. What you don't know won't hurt you.
You think I'm stupid? You want me to fill you in on the details? You think I like swimming in shark infested waters?That's a great way to participate in a forum that's set up to share information and experiences.![]()
I am running Quaker State Ultimate Protection in my F150. I have 3,300 miles on the OCI at the moment and I just did a check this morning...the oil is amber colored. It is the OP's engine, not the oil. For reference, I checked my wife's Altima which is running the new Mobil 1 Extended Performance. It has 2,800 miles on it and the oil is dark brown. Either way, the color doesn't matter."Coal black" at 700 miles is definitely unusual. Does that happen with all oils or just Quaker State?
The size of soot is not an issue here, it’s the amount of it.
As the article said only one way to find out. Sample.The size of soot is not an issue here, it’s the amount of it.
OP mentioned coal black oil in 700 miles. That is only normal in diesel engines.
This much soot will eventually start depositing in the engine as gasoline oils don’t have the same amount of dispersants and detergents to deal with it.
Also, not sure how many here handled old diesel oil. Rub some between your fingers and see just how much soot gets imbedded in your skin and how sticky it is.
Soot particles may be small, but they do lump together into bigger ones if the are not suspended in the oil. If soot starts to deposit itself in the engine, it will eventually cause trouble.
"It’s common to assume that black motor oil has worn out or become too saturated with contaminants to protect your engine and requires changing. Not necessarily. As we saw, discoloration is a natural byproduct of heat and soot particles, which are too small to wear out your engine.Sure, if you want to know the exact amount of soot the oil has.
But most of you keep repeating that oil color doesn't matter where it actually does. The darker the oil, the more soot is in it. And if the oil gets coal black quick, where others with the same engine don't report the same, means there is an abnormal amount of soot there.
I read what blackstone has to say about it and their normal is 1%. They don't mention if it's for diesel, gasoline or both. I presume it's for diesels since they have an example from a VW TDI engine.
Is the same soot loading of 1% being safe in diesel engines, with diesel oils can be assumed to be safe in gasoline engines with PCMO oils?
