Current synthetics that are PAO based
North Carolina
What current synthetic oils are PAO group IV based ? I have heard that Mobil 1 Extended Performance is?
Grp III,as with all of the otc synths.
^ That's not entirely accurate. III+ with PAO. 0w40 contains PAO as well and is not all Visom. Look at the Japanese MSDS. It doesn't matter anyway.
I remember seeing a Japanese pds a few years ago (way before the Visom powerpoint) that said the Mobil 1 15W50 was a grp IV/V oil. Now that the Visom grp III stuff came about,I wonder if this is still the case? BUT,the Visom powerpoint said all Mobil 1 oils were "shifting from pao to grp III without alerting the consumers". That's the only current evidence I've seen.
The same ones that were in last week's identical thread, and the same ones from the week before that. Other than certain boutiques, certain HDEOs, and some European type oils, we don't know. Even then, it's dicey. A safe bet is that an oil that only meets SN/GF-5 is probably not going to be primarily PAO based.
Actually this is not true for Mobil 1 oils. There is some grp3, but all Mobil 1 oils also have esters and PaO blend.
Originally Posted By: artificialist
There are certain Amsoil products that are all PAO.
Not sure about that. Maybe Pablo could shed some light on this.
I think the better term would be "primarily PAO", as there's no lubricant that is 100% a particular base stock. The Signature Series oils are primarily PAO-based.
Castrol 0w30 and Castrol 0w-40 are probably heavy on PAO seen by their extremely low pour points.
Also, Mobil 1 0w30 has a pretty low published pour point, so it may also be heavy on the PAO.
Originally Posted By: StevieBoy
I'm only sure about Red Line. Their web site says,"Fully-synthetic ester formula..."
And of course Red Line uses PAO as well. No oil is 100% ester of any variety. No oil is 100% PAO.
It doesn't matter. Or it only matters to people who THINK they are somehow outsmarting others/the system/basic organic chemical concepts/science/the general tribology body of work by using an oil with this or that base oil.
Question is obsolete. It doesn't matter. Who cares. More important things in life. Its been debated into oblivion. No longer considered valid. More marketing than performance based. Question should be retired. We have all moved on. Makes 2/5ths of 3/8ths difference for street driven cars. Hydro-cracked XHVI oils rule.
And with that does anything else need to be said.
Ha.
Awesome
