EngineeringGeek
Originally Posted By: doitmyself
The only way you could know this is if you do a number of used oil analysis with both oils. Are you going to do this?
FYI, I commend your diligence and efforts. I do this kind of investigation numerous times at my workplace. In some (many) instances, I end up where I started. But, at least I am better educated about the subject matter.
Kudos for keeping your cool and replying intelligently to some of our lame rebuttals.
Thanks. I'm not sure if I'll try two different oils or not. If Brand A has a disappointing UOA at whatever interval I decide to change it that would provide incentive to try Brand B. But if Brand A is looking good, I'll probably just stick with it and keep that change interval or even extend it a bit.
If I do switch, and Brand B is no better, I'm not sure what I'd do at that point. I could go back to A, stay with B, or try something different (C). Odds are I'd just stick with B and shorten the change interval.
It's sort of interesting to look at the major brands from a standpoint of what their likely design goals are. Obviously each would like a competitive advantage of some sort to give their marketing department something real to work with rather than the usual F.U.D. (fear, uncertainty and doubt) and other useless nonsense.
Reading between the lines, and looking at the reports, it seems Castrol probably optimizes towards high temp high stress operation at the expense of cold performance. Pennzoil seems to go for lower deposits/cleaner operation and thinner viscosity/better cold performance. Valvoline emphasizes low wear and is fairly similar to Pennzoil. Mobil 1 is somewhere in the middle (but doesn't do very well at 150C HTHS or cold performance).
The three premium brands I looked at seem to mainly push their allegedly superior stocks--either because they're more green or otherwise somehow supposedly better. But I haven't seen any lab data that shows they perform any better overall than the current cheaper brands. The one exception being one of the "green/eco" synthetics I looked at had the best cold pumpability of any 5W30 I've seen but it was otherwise an unremarkable oil, it's at least 2X the cost, and it lacks several certifications the cheap oils have.
