Originally Posted By: ltslimjim
Chart sorta scary comparing API/ILSAC to ACEA A5/B5.
Yeah, using that link above it does seem scary. Just from reading the tests it's obvious A5 is a far tougher standard on many levels. And GF5 is a big step up from SM/SN. GM's Dexos1 adds its own twists to GF5.
Many of the name brand cheap 5W30 full synthetics (i.e. Synpower, Platinum, etc.) are A5 certified. Platinum is also Dexos1 certified.
I ordered some reports from IOM and have concluded the following for 5W30 and (mostly) A5 rated oils:
Valvoline Synpower and Pennzoil Platinum are very close. Each edges the other out in a few categories but they're more similar than different. Platinum has a significantly higher TBN which could be useful for extended drain use. But the flip side is it's similarly worse for oxidation which might hurt it for long intervals.
Mobil 1's "Extended Performance" is typically cheaper than Pennzoil Platinum at big box stores in jugs but its cold pumpability is notably worse as are several other measurements.
Castrol Syntec is even worse than Mobil 1 for cold pumpability--the numbers make it look more like a conventionally refined oil.
I won't name any names, but some of the "premium brands" that cost around twice as much as the above (or more) really don't have much of an advantage on paper--either when new or in lots of used oil analysis that I reviewed. I know some like to trumpet a test or two they ace, but all the basic numbers are usually +/- 15% of the $25/jug stuff.
All of the above oils have similar HTHS 150C performance which surprised me. They all easily clear the fairly strict A5 standard. I was expecting that to at least be a big difference with the expensive premium brands. But it's not.
Considering there's lots of evidence most engine wear happens during cold start up, my inclination is to favor the oils that do better when cold as, from the numbers I've seen, they don't give up anything significant at 150C in the HTHS test. That's especially important if you live in a cold climate and/or make lots of cold starts.
In terms of sludge/deposits Platinum and Synpower also seem to do at least as well as most of their competition. I don't really know which one will win at the end of a long change interval, but judging from the used oil analysis I've seen, the premium brands don't seem to have any real advantage there either. The used oil analysis results I've seen seem more tied to the vehicle, its total mileage, climate, how it's used, etc. rather than the oil.
The ACEA A5 certification is a good start for extended drain use but it's been really interesting to look at indepedent test results. I think there's a lot of marketing hype and spin out there. The real differences are smaller than I expected.
This is also consistent with PQIA's tests of conventional name brand oils. The differences across the board were typically under 15% but they only run a few tests compared to IOM.
