Synthetic Comparisons
quote:
Originally posted by Pablo:
They don't have to locate a dealer for you. I'm your huckleberry.
If you had a technical question you can ask me or the technical contact at Amsoil via the webpage. I answered your Dexron IIIH question. With yes Amsoil meets IIIH.
Are you refering to the Universal ATF because it just says Dexron III with no (h) designation?
For the rear end would it be the Amsoil 75w/90 EXTREME GEAR fluid and you would you have to add additional Amsoil modifier 4 ounces?
As I said, yes it meets the H revision.
You may need the additive. Which differential do you have? I'm assuming you have a limited slip diff. - you could try it neat - and after a bunch of figure 8's in both directions - if hear any interesting sounds - add either GM 1052358 or Amsoil Slip-lock
quote:
AMSOIL SEVERE GEAR™ is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
It is a 2005 Corvette with A-4 transmission. Rear end diff is 1.8 quarts. The dealership is going to put it in for me so it would have to be a one shot thing. There wouldn't be any harm in just adding the Amsoil slip-lock anyway would there?
The AMSOIL gear lube is formulated for use in anti-slip rears. In over 26 years of handling the products, I've had 3 (that I can recall) who had to add additional additive.
Just be sure to go out and drive the vehicle in figure 8s after the change, to be sure the fluid is well distributed.
Should you have a slip-clack, then you can add the additive. There will be no damage--the noise would drive you out of the car before that would happen.
I would rather do everything in one shot and one visit when I have dealership do this. Otherwise this will count as two visits and two charges. Should be no harm in adding amsoil additive if it does no harm.
Adding LS additive when it is not needed can result in an ineffectual LS rear end, worst case it would be not LS at all and be full slip , just like an open diff. Then when you need it, you won't have it, and end up stuck.
reyjay1 - I agree if you add too much, this could happen. I doubt it would happen with the prescribed amount of GM or Amsoil additive. My original recommendation is SVG neat.
Redline should be fine too
I'd like to know... Amsoil states 25k mi OCI. Mobil 1 doesn't, but, if they're arguably similar, can't you take Mobil 1 up to 25k mi?...
I've just bought a brand new Toyota Matrix, and am thinking of going back to Amsoil. Mobil 1 is available @ Costco for ~ same amount.
For my 2005 Corvette I stick with the Mobil 1 from Costco it went up in price to $27.72 for 6 qts. Mobil 1 is so much easier to find and purchase and is less cost than other synthetics.
For the rear end diff. and auto transmission I will decide between Redline or Amsoil or perhaps Amsoil 75w/90 Severe Gear and Redline ATF provided these meet/exceed (MOST LIKELY EXCEED) the GM SPECS.
For my 2005 Corvette I stick with the Mobil 1 from Costco it went up in price to $27.72 for 6 qts. Mobil 1 is so much easier to find and purchase and is less cost than other synthetics and don't forget it is the factory fill for the Corvette so there is no question whether or not it meets or exceeds GM specs.
This is the Corvette spec right? It is kind of funny as I have always heard they come factory-filled with Mobil 1 so it seems ridiculous Mobil 1 Extended Performance doesn't meet the spec. I bet it does but it hasn't been tested or certified yet or something to that extent.
quote:
Perhaps but I looked on the back of a bottle of Mobil 1 extended and compared it to the 5w30 Mobil 1 and it doesn't specify the "GM 4718M" spec.
I will say, when I was using Amsoil, I lost much less oil during the OCI than with any other brand, including M-1. I'd still like to know if M-1 would last to 25k mi as well as Amsoil claims it will.
Don't forget. AMSOIL claims 25 k miles with a 6 month oil filter change during that year, using their oil filter and one of their air filters (at the time it was the foam filter I'm not now). The SDF filter was made to hold lots of crud so I'm sure that helped the 25 K promotion. The new filter is stated for 25 K.
Does Mobil 1 claim 15 K miles ONLY with their Mobil 1 oil filter I wonder?
