Ultimate 0W-20 (ultimate PCMO) contest:
My 4A-LC seems to be running great on PYB 5W-20, which is Group II+ with a huge load of moly. Moly probably helps a lot, as Group II+ base oil otherwise has more friction and causes more wear than Group III, which in turn has more friction and causes more wear than Group IV -- at least in theory. Additive package, including the detergents and wear additives, makes a big difference as well.
I will do a UOA at the end of the OCI to see how wear is actually like and if my 1980s engine is actually happy with 5W-20 inside, despite calling for 10W-30. Since the new Toyota engines have virtually the same clearances and I have very little oil consumption if any, the recommendation on the viscosity is probably thanks to what was popular and mainstream back then.
It will be time to switch to the ultimate PCMO in the next oil change: a synthetic 0W-20. I want to hear your opinions in choosing the best one. At the end of the day, it's the magic recipe of the right base oils and right additive package which makes the best oil, but unfortunately, the oil manufacturers are not required to disclose their test results and we never know which is the best:
Toyota Genuine Motor Oil 0W-20 (made by ExxonMobil): Probably the cheapest ($5 per quart if I drive 25 miles to a certain dealer). Highest viscosity index. Good amount of ZDDP and moly. Downside: probably mostly or entirely Group III, not a true synthetic, meaning more oxidation, more evaporation, more friction, and more wear than a PAO (Group IV) base oil.
Mobil 1 0W-20: Probably entirely PAO and Group V -- true synthetic -- which is good. But ZDDP very low, probably only 600 ppm, despite the 800 ILSAC upper limit. Also historically high wear numbers with Mobil 1 oils. Fairly expensive unless you catch a sale.
Amsoil Signature Series 0W-20: Entirely PAO and Group V -- true synthetic. Very high TBN for extended OCI. But very expensive. Also, not a mainstream oil, which leaves a question mark in your mind.
Other 0W-20: ?
So, let's hear your opinions. I don't want to hear opinions such as there is no best oil. Do you have any UOAs on the SN formulations of these oils? I don't want to hear opinions saying UOAs are useless either.
By the way, here is a great reference on how the Group II, III, and IV base oils compare in volatility, friction, solvency, wear, etc.:
Yubase (largest Group III manufacturer) reference on Group III performance (PDF file) (more references on their Web site)
Other 0W-20: ?
