Originally Posted By: Smokescreen
The 09 Corolla 1.8L engine does have a different number, 2ZR-FE designates dual VVT-i (intake exhaust valves 132hp), the former number was 1ZZ-FE the single VVT-i (intake valves only 126hp). Other that the valves the engine (except oil cartidge filter) is the same I believe.
This is incorrect. This is how Toyota numbers most of their engines:
ABC-DE
A = "Revision" number
BC = Engine family
D = Power/Economy designator (F = Fuel Economy, G = Performance)
E = Electronic engine control
A 2ZR-FE (as the non-XRS 10th generation Corolla [2009+] uses), is a ZR engine, completely different from a ZZ engine. Every Toyota ZR engine has Dual VVT-i, not just the 2ZR-FE. There's a 1ZR-FE, which is a 1.6L version. The 2ZR-FE is the 1.8L version. There are a few other versions, used overseas:
http://en.wikipedia.org/wiki/Toyota_ZR_engine
Again, there are obvious similarities between the ZZ and ZR engines (both are alloy 4-cylinder engines), but the engines are completely different designs.
My brother has the 07 Corolla and was thinking of switching to 20wt. Good to know about the consumption there as well. I was right to advise him otherwise.
I used 5W-20 PP in my '07 with the 1ZZ-FE and experienced no oil consumption. I did only use that on one OCI though. The 5W-30 just feels better to me in this engine, so that's what I continue to use today.
