Is Dexos 2 safe in a 2012 Denali 6.2
Curious if a 5w-30 Euro Dex 2 is safe to use in a Dex 1 LS3 6.2 with AFM, motor has 130K
Was thinking on the Penzoil Euro L 5W-30.
Nothing wrong with engine, just toying with options.
Motor loves Redline, but curious to other slightly "heavier" oils with higher HTHS.
(edited)
Of course, these engines aren't lspi prone. I use 5w-40 euro in my 2021's 6.2 but I'll probably switch it to 15w-40 since it doesn't get cold where I'm at.
I wasn't aware of any LS3 engines that have Active Fuel Management? Maybe in the trucks? But I think it would be a different engine designation?
You are correct, I misspoke.
I had it in my head back in the day that the Gen 4 LS 6.2 is a variant of the LS3. May or may not, but proper term is Gen 4 LS.
(edited)
My motor loves long walks on the beach, puppies and a good, warm cuddle.
(edited)
Yes, it will work fine. However, you have to consider that a motor oil like Pennzoil Euro L 5W-30 is primarily formulated to protect the emission systems on light duty Diesel engines. You have a gas engine with a catalytic convertor. If it was mine, I would pick a motor oil that prioritizes high performance and protection against wear, like:
  • Mobil 1 FS 5W-30/0W-40/5W-40 (API SP, the 5W-30 uses the same API SP add pack).
  • Quaker State Euro 5W-40 (API SP)
  • Castrol Edge Euro 5W-40 (API SP)
The above is what you can find at WM for a reasonable price. Good luck!
