- Joined
- Dec 30, 2006
- Messages
- 29,558
Haha no way! I just listen at work. Everyone listens to music and I listen to talk radioAre you a talk radio host?
Do they at least have a drain pan around them in case they burst? Seems like an odd place to put water heaters that may weigh 500 pounds when full. Is that code legal?My water heater tanks are in the attic, should they be drained as well?
Yes, drain pan is present. I suppose it is legal, bunch of houses around here are built that wayDo they at least have a drain pan around them in case they burst? Seems like an odd place to put water heaters that may weigh 500 pounds when full. Is that code legal?
I wouldn't worry about it too much. Your idea of shutting off the main valve and draining what you can sounds good. Here in Wichita Falls, during that crazy week in Feb 2021 we saw 0 degrees two nights in a row. My power was out for most of that time, but it never got colder than about 50 degrees in the house. People with older homes built over a crawl space were the ones who got the lion's share of the busted pipes.It’s on the slab
Is it one of those compact type water heaters? Lots of those installed in attics around here.Yes, drain pan is present. I suppose it is legal, bunch of houses around here are built that way
Similar to my bay house - I shut in main valve and drain to outside faucets - leave open - (flip breaker to water heater) …This is happening again. Temperatures are expected to drop to 15s here up north of Houston. I wouldn’t be as worried, but going out of town for a few days tomorrow. Trying to figure out what to do with the water. Cut it off (shut off valve is in the garage) and drain all faucets? My water heater tanks are in the attic, should they be drained as well? I guess I’d need to turn them off as well?
What would be the right sequence here guys? Last two freezes I was around and no issues to speak of. But now since house will be empty, I’m getting super anxious
That will not drain the tank, if installed properly it fills from the bottom (via internal pipe) and empties from the top. If you only shut the water off leave the tank on.Shutting off the water supply is fairly easy I suppose, valve is in the garage. How do I deal with the water tanks? Turn them off first, cut off the water supply in garage, and then open all faucets and let it all drain?
It's weird but quite common in the south to put everything in the attic. Water heaters, HVAC ... I guess it helps with space since the house is built on a slab.
Good point - because I did it so often at the bay - had that outlet piped with PVC …You can attach a garden hose to the drain valve at the bottom of the tank, run it into a sink or bathtub, and open the drain valve and let it drain. Make sure the gas or electric is turned off to the tank before doing this, and do not turn it back on until the tank is refilled (no more air spitting out of the faucets).
I was just talking to my buddy, and he suggested to shut the water off at the main valve, drain cold water from all faucets, but let the tanks alone. Those tanks are pressure fed, so if there’s no pressure in the system it will just maintain the water temp in the tanks it’s set it. Does that sound reasonable?That will not drain the tank, if installed properly it fills from the bottom (via internal pipe) and empties from the top. If you only shut the water off leave the tank on.
It is ok. But having those tanks on the attic doesn’t give me warm and fuzzy feeling. Having HVAC sitting next to them is even worse, it gets to 130 easily during the summer time and cooling efficiency is taking a huge hit. But, that’s how it was built..That’s a nice looking set up! Your attic is spotless!![]()
