Most of the advanced and exotics have oil thermostats. They also may have bigger sumps.
In my observations over varied starting temps (like mid teens through just 85F), you reached the major gains at about 9miles/9minutes. The number may vary (let's say 155-170f) but the time to full temp would be the same. It's really creeping for the last 10f and will back right down when power is removed. It was, in my case (reading from oil filter output) immediate. Like from 213-215f to 190-195f in seconds.
The difference in time to thermostat setting, other than the natural impact of lower ambient temp, in my case have been on smaller engines with unremarkable power density. For example, my 2.5 engine probably doesn't even need the radiator in sub freezing weather for anything other than highway usage.
When I first started my 0w-10 oil trials, I attempted forced heating and cooling on my 3.0 Mitsubishi. My goal to simulate a smaller sump for startup (the idea came from a member named Curious Kid, iirc) and introduce more oil after warm up. I couldn't make a 5 quart sump into a 2 quart, but I could make a 7-9 sump look like a 5. I also wanted to have the advantages of a 0w-10 for warm up, but wanted to manipulate its hot temp to 180f to make it appear like a 20 grade. I used Ford Crown Vic adapted heat exchangers (they take a 1/2 NPT or 3/4-16 JIC thread easily, btw). I also used a couple of tandem'd Eaton tow motor transmission heat exchangers. There I used oil thermostats as coolant thermostats for the Eatons in an attempt to sequester the coolant until it reached 180F.
The bottom line in that whole setup (above) was that I found that actual coolant temp varied more than I expected. That is, even a 195f thermostat produced 20f+ dips in intake manifold outlet temp (temp sensor location).
Granted I couldn't really take the time to explore any and all interesting side effects as I was playing around in novice/hobby grade experimentation. It did teach me that there's a lot more complexity to managing things into the narrow confines that we want ..but also that there's an ample amount of forgiveness in the margins.
