I didn't read that part of the caption.
FWIW, the MRV limit used to be lower, like 42,000cP or 48,000cP or something, and the reason for that was that this was the limit for the AMC/Jeep 4.0L I6 oil pump + pickup combo. That was eventually deemed "obsolete" and the newer limit of 60,000cP adopted to reflect more modern applications.I’m wondering if there is possibly something wrong with his oil pump or oil system. Even with the 5w40 it takes a long time for oil pressure to come on, longer than I would have left it running to be honest.
Hinton,AB isnt very far from me and I’ve started many engines with 5wXX and 10wXX in those temps and didn’t have issues with oil pressure.
The guy with the Civic does,The only thing missing was him revving the crap out of it.
How do you figure that?Canadians tend to like thicker oil than us Americans it seems.
Back in January and February 1963 living in rural DownEast Maine, the temperature went down below -20F for a few days. My 1962 Buick always started using 10W-40Started Opel Vectra B at -42c having 10W40 in the sump.
I'm in new Mexico where I usually doesn't get below -10f and I run 5w-30 group 3+ oil in my old dodge.Regarding the third example into the video around minute 4:30
He's running "regular" 10w-30 (presuming he means conventional), AND LUCAS OIL STABILIZER ... then he changes to a "warmed" 5w-40 and adds Seafoam.
So he's got money to waste on additives, but can't afford a decent 0w/5w-30 PAO based lube?
I'm gonna say it out loud .... Idiot!
Torpedo heater!Or at least an oil pan heater
Unless of course, it couldn’t be pumped as it wasn’t here.While 10w30 is not optimal for sure, it would’ve built oil pressure a lot sooner if it wasn’t handicapped by the Lucas junk additive.
Not being able to be pumped is a poster child illustration of exactly what the winter rating represents.Yes, and CCS is usually what determines the Winter grade.
Absolutely. It's just typically that CCS is what hits the limit first, since that limit is much lower.Not being able to be pumped is a poster child illustration of exactly what the winter rating represents.
That’s your assumption and you’re also assuming that the additive didn’t affect the pumpability, which it 100% did.Unless of course, it couldn’t be pumped as it wasn’t here.
The winter rating sure seems to be a confusing subject for many people.
No, I was agreeing in a way that the additive certainly may have affected that. It probably did.That’s your assumption and you’re also assuming that the additive didn’t affect the pumpability, which it 100% did.
There is an old Mobil 1 video that compares a Dino 10w30 to their synthetic 5w30 that was done at -35c. 10w30 pumped in that video.
An oil doesn’t go from pumpable to not pumpable just because it’s few degrees outside of the cold grade rating.
I’m not entirely convinced of the binary characteristics of the oil.However that is exactly what the difference is. It’s either pumpable or it’s not. It is a binary. That old Mobil video probably illustrated the fallacy of using pour point for predicting borderline cold weather performance of an oil.
