For those of you with mighty vacs do you just dump out the extracted fluids or do you do some sort of rinse and clean?
If you do rinse and clean what is your process?
Thanks. I'll have to look at that vs the cost of solvents. Pulling samples was a secondary consideration and I am reaching the point where there is little left to learn from UOAs where the manufacturer's recommendation isn't exceeded. A UOA costs about the same as an oil change on a little four banger, so why bother?Pull a sample with one of these. Use new line to avoid contamination.
Oil Analysis Sampling Pump - Accurate Oil Extraction of Various Engine Oil
https://a.co/d/ibGkS5g
Use the Mityvac to remove oil for disposal.
I would get a normal oil sample pump if you need to pull samples between oil changes. You use new tubing and sample container for reach sample and almost no oil touches the pump if you take the sample properly.Yesterday I purchased a fluid extractor from Harbor Freight that is similar to the Mighty Vac. The initial intent was to draw off some oil in a vehicle and replace it with HPL EC30. The secondary purpose is to pull oil samples for the lab without actually draining the oil. A case in point here is my 2017 C-Max Energi with 12K miles on the oil vs. a 20K recommended OCI. In any event I am wondering how to clean it well enough to avoid cross contamination of samples. Suggestions I have found online thus far include the following:
I would welcome any personal experience from those of you using something like this to draw samples.
- Warm soapy water. Dawn and Simple Green were each mentioned a few times.
- Brakeleen was mentioned
- Denatured alcohol was mentioned
- Acetone was mentioned
- Several references combined either alcohol or acetone followed by the hot soapy water treatment
Does the product in the link you provided mate right up with a Blackstone sample bottle?Pull a sample with one of these. Use new line to avoid contamination.
You can get one directly from Blackstone. I've had one for years, they supply the tubing which is easily replaced at your local hardware store, it's refrigerator defrost drain tubing, very inexpensive.Does the product in the link you provided mate right up with a Blackstone sample bottle?
I bought one of these on Amazon. It didn't come with the tubing needed to reach the sump. The instructions are printed in a two point font that I need to use a magnifying glass to read. It seems that it will accept tubing from 3/16 to 5/16-inch. That's a pretty broad range. What size and type of tubing do you suggest?Pull a sample with one of these. Use new line to avoid contamination.
