Clark C500-40 forklift
Hawk Seale
We just bought an older C500-40 forklift with a Mitsubishi LP engine, and need some advice on where to find the Engine oil drain plug.
Also there is a tank on the Left side ( standing behind ) that has nothing in it, anyone know what would it is for. I assumed it would be hydraulic oil, but stuck a tape in the tank and nothing.
And lastly, where can we get new steering tires? Thank you
That might be the gas or Diesel tank...That should be empty if it is a LPG
The Drain plug should be on the bottom ... i rember seing the guys slide the drain pan in and out from under it.
Call a Clark dealer or any Forklift dealer to ask them ?
Thank you Rudy, that makes total sense on the fuel tank. Kschachn, I will found a dealer from your search in Waterloo, IA, So will check them out Friday as I will be in that area. Thank you.
