From the (assumed) article on that site:
John C. Lai wrote that LubeGuard, used with Dexron by AAMCO, is not a good substitute for ATF+3, either: "...although Lubeguard claims on their website that their product will convert Dexron to become an ATF +3 (7176E) equivalent, they actually have no test data to back that up. In fact, their head engineer told me that the tests they did were conducted in the early 90s with the first version of 7176, several years before ATF+3 was developed. So, they have no basis for their claims of ATF +3 equivalency."
I'm wondering who John C. Lai is? Is he some noted automotive expert? I don't see any "John C. Lai, in his report to Autotrans Rebuilder Quarterly"
So the transmissions that were using the original 7176 were using lame fluid from the factory
and needed revisions that Chrysler failed in original fluid??
My 30rh (a 904 3 speed) needed only Dexron, in it's various configurations, for over 30 years. The only introduction of 7176 (hence evolved into +3) is because ...and ONLY because of the infamous converter clutch ..and for no other reason whatsoever. This doesn't mean that +3 isn't different then older 7176 (a-d) specs ..just that those modification should have no impact or advantage beyond their usefullness to other aspects of more sophisticated and weak knee'd Chrysler transmissions.
That is, your 3 speed with a lockup ..allegedly ran fine from the factory ..and for (probably) 80k on the original 7176(a?) ..what makes a modifier (that 10's of thousands of rebuild shops used to convert Dexron III) that has been tested to "a" specs, dysfunctional
My 92 3 speed (now without a lockup due to rebuild BECAUSE of the lockup converter) has had Dex III for 90k. One would assume that if the fluid was the cause ..that I've doubled the OEM lifespan of the original trans and surely would have encountered some issue.
