Looking at the Canyon.
2.7L Turbo
27 psi boost??!!???
Cylinder deactivation?? is that true?
2.7L Turbo
27 psi boost??!!???
I don't think it has anything to do with the cost of the next 50k+ purchase but I see your point that a typical trade in customer might not mind but I have a hunch it would be a couple thousand in trade in lost vs the V8 trucks especially when it is treated as an option vs base 2.7. This is my initial thought process....BUT!!! I went on Kelly Blue book and did the value on identical trucks (2022, LT trim, 4X2, 40k miles and very good condition) but one with the 2.7 and one with the 5.3. I was astonished that the values were IDENTICAL! The trade in was 31,415 and private sale was 34,987. So with the 4 or the 8 you get the same value. I am totally surprised by this. Next I am going to check real world sales and what's on the lots now !! lol!It will be far less than a $1,000.00. Not enough to affect you if you going to turn around and buy another $50,000 or $60,000( or more) truck.
I'm surprised at that as well....but as I stated originally-it isn't going to be much-in the big picture. Excluding the Maverick (even though prices have crept up) there are no "bargain trucks" Chevrolet/Sierra (new style)-regardless of motor size.I don't think it has anything to do with the cost of the next 50k+ purchase but I see your point that a typical trade in customer might not mind but I have a hunch it would be a couple thousand in trade in lost vs the V8 trucks especially when it is treated as an option vs base 2.7. This is my initial thought process....BUT!!! I went on Kelly Blue book and did the value on identical trucks (2022, LT trim, 4X2, 40k miles and very good condition) but one with the 2.7 and one with the 5.3. I was astonished that the values were IDENTICAL! The trade in was 31,415 and private sale was 34,987. So with the 4 or the 8 you get the same value. I am totally surprised by this. Next I am going to check real world sales and what's on the lots now !! lol!
2.7L Turbo
27 psi boost??!!???
Wondering if it boosts in 2-cyl mode? I guess not.Looking at the Canyon.
2.7L Turbo
27 psi boost??!!???
This is pretty good: https://www.motorreviewer.com/engine.php?engine_id=193Wondering if it boosts in 2-cyl mode? I guess not.
I think it is. And it can run as a 2-cylinder. There’s a lot of engineering into it. I suspect it will be a sweet motor for the canyon/colorado. There are some pretty good articles out there on it.Looking at the Canyon.
2.7L Turbo
27 psi boost??!!???
I would imagine It has to, to a degree. These engines wont run at all w/out the turbo. Like if you disconnect the air duct from the charge air cooler outlet to the throttle body, or even if you have a small leak/crack in the air duct, they'll go in limp mode at best.Wondering if it boosts in 2-cyl mode? I guess not.
Side by side how does this compare to the Tacoma 4 cylinder turbo?
All aspects?
Lack much detail on corporate sales sites......wish GM had torque # at ~2000 rpm
GMC:
Toyota
- 310 hp [231 kW] @ 5600 rpm
- 430 lb-ft of torque [583 Nm] @ 3000 rpm
- 278 hp @ 6000 rpm
- 317 lb-ft @ 1700 rpm
Anecdotal, but my friend had major issues with his 2.7 paired with the 10 speed in his Silverado 1500. The tranny would refuse to upshift, and the engine would throw codes with loss of power. This was with only 40,000 miles on the truck. Ultimately ended up dumping the truck and going back to a 5.3 1500 with no issues since. Could have been a lemon, but would make me leery. I know for a fact he is good about his maintenance and not hard on trucks.
Imo, I haven't been a fan of any transmissions in the last 10 years or so. They all seem to stay in higher gears too long so you have low RPM for MPG but no power. I may have to consider tuning my truck to hold onto gears longer.Meanwhile the 8 speed behind the Toyota 2.4T has been failing as well.
Unironically mine has been having shift flares when cold. *sigh* Welp...
GMC:
Toyota
- 278 hp @ 6000 rpm
edit: added "a fan". Helps to have a complete sentence![]()
