OK, junior chemists. Get out your chemistry sets!
I checked the MSDSs for one "premium" and two "cheapo" engine flush products and came up with these basic formulations:
1. Auto RX - long term use
--% Lanolin esters
--% aliphatic ester
--% polyol ester
2. Valvoline/Pyroil Engine Flush - 5 min flush
85%-95% kerosene
3. Alemite CD2 Oil Detergent - long term use
100% of two different grades of mineral oil
My question is, what are the basic pro's & con's of these formulations? Such as impact on seals, impact on lube oil performance for longer-term use, and the possibility of scavenging large quantities of sludge/crud into oil passages at one time. And before it inevitably comes up, I'll suggest that just because kerosene and mineral oil are cheap, low-tech formulations doesn't AUTOMATICALLY mean they're "bad" treatments. I was hoping for a few objective thumbnail comments as to the precise affects a chemist would expect from each of these three formulations. THANKS!
One last thing...
Valvoline claims "Pyroil Engine Flush dissolves sludge gently. Some engine flushes are too strong and can plug critical oil passages with dislodged particles. Since Pyroil Engine Flush contains no chlorinated solvents or low flash solvents, it is safe to use." I'm wondering, how can one "gently" remove sludge from an engine in just 5 minutes? Isn't that like "gently" removing a room full of wallpaper in just 5 minutes?...by "gently" using small explosive charges, I presume?
[ November 15, 2003, 10:19 PM: Message edited by: TC ]
--% Lanolin esters
--% aliphatic ester
--% polyol ester
85%-95% kerosene
One last thing...
