- Joined
- Dec 28, 2011
- Messages
- 5,614
Cooking is highly dependent on temperature. Eggs especially require the right temperature. Preheat and use a quality temperature gage. Oil needs a bit to warm up as well.The Blue Dimond egg pan looks just like the one I just purchased.
https://www.amazon.com/Blue-Diamond...efix=blue+diamond+single+egg,garden,98&sr=1-4
I used one for a while, eventually they both warped and leaked a bit, but they do work good.
Hand wash drip dry. I usually like to cook eggs as low as I can get the gas burner but I did try letting the oil get hotter before adding the egg and higher heat but it made it stick more.
Even with the T-fal I use a bit of oil, I like what it does to the texture of the egg plus on sandwiches I like them fried so they are a little crispy around the edges. About half way thru cooking I bust the yoke and spread it around.
I find it interesting the response here are almost identical to the reviews, some say the do some say they don't, makes me wonder if it's QC.
Most often a quality skillet conducts heat evenly and often, unless searing, knows of gas stoves sit in the 3 to 7 range.
