Originally Posted by SubieRubyRoo
Stevie, one of my other posts I linked a white paper from MIT on the various paths that oil into the PCV system is generated. If a vehicle has a PCV system, it's an engineering impossibility to keep all of the oil out of the system. Tighter rings, PCV baffles, other trickery can help, but it's a simple fact of oil that "some" portion is going to vaporize; either from heat, from being slung around mercilessly by the rotating assembly, or yada yada. I think the only real way to eliminate all intake issues would be a line from the PCV to some tie-in point after the converter. But obviously then you run legally afoul of several things... plus you take the chance of the oil not being hot enough to fully vaporize, and dripping liquid oil out of your exhaust.
I figured that 100% is not achievable... I get that.
If you really want to get fancy, save the cup drippings until you can fill an oil sample cup with it, and send it out for a used oil analysis. That would tell you how much was water, how much was fuel, and how much was oil. The makeup of the oil is really insignificant other than to see what parts of the additives made it all the way through the system.
Good idea, I would be curious to see what it's made up of.
