Castrol Syntec 5w50 overkill for my application?
Frisco, TX
It's not that I don't love my current fill of Motul 300V 5w40, it's just that I cringe at the price everytime because of my 10qt sump.
It's been at the back of my mind for a while to use something else. Was passing through Autozone yesterday and noticed they are selling a Castrol Syntec 5w50. My car sees plenty of track time and I do drive the car hard.
The reactions to this oil seem to be mixed. The VOAs look really solid, and it has a good VI of over 200. But some claim it shears to a 10w40, and others say this is untrue.
Would this be a good choice for my motor, or am I safer with something like Mobil 1 0w40, Red Line 5w40, etc?
Syntec 5w-50 is a group III oil, which means it must be using quite a bit of VIIs to achieve such high spread, and when VIIs break down, the oil loses viscosity and potentially leaves deposits. Personally, I would stick with the other oils you mentioned.
If you really feel you need thicker oil, you might want to look at Mobil 1 15w-50, but I'm pretty sure Mobil 1 0w-40 will suffice.
Well there is also Mobil 1 5w50. Not sure how different of a formulation that would be.
Where do you find Mobil 1 5w-50 in Chicagoland area? I've seen it in Europe, but never here. Supposedly it's a good oil, very popular in many other parts of the world.
if you're looking for it in Chicagoland you can try G&H Import Auto Parts (I think that's the Name of the place)in Oak Lawn it's around 99th & Cicero.
Hi,
Mobil 1 5W-50 is a very good product and as an example it is the only SAE50 lubricant (since MY99) that has Porsche Approval. It has been a best seller here in OZ for a decade or more. Most post MY84 Porsche engines use Mobil 1 0W-40
However, that said I would be very inclined to use a 0W-40 (or a 5W-40) lubricant in this application
Syntec 5W-50 is a very sensible lubricant for some applications and carries a good pedigree, it was Porsche Approved up until 1999
I would run the same weight oil you are running. Seems too cold,up there,for a 50-W.
My BOSCH shop uses it by the drum, inc S cars and P cars.
I'd consider Mobil 1 10w-40 HM. It's a thick 40 that should do the job very well.
There is always Rotella too.
Is this simply too thick for my motor? Bear in mind it is kept in a heated garage and is not a DD.
Hi,
Dan - Others on here will disagree of course but IME it always seems best to use the lowest Approved viscosity for the ambient range anticipated/encountered
Many times and especially with some Euro engines the lubrication system's by-pass is in operation far too long and too often when using higher viscosity lubricants than is really needed
Originally Posted By: Doug Hillary
Hi,
Great points Doug! Truth is I'd be willing to wager not many people really know when the lubrication system is in by-pass either. They just think they are doing their engines good because they think thicker is better. That isn't always the case.
Interestingly, both Mobil 1 5w50 and Castrol Syntec 5w50 have the same KV @ 100C of 17.4. That makes them very light 50-weights. (as opposed to Syntec 20w50 that is 19.7 and more in the middle)
The oil in the sump right now has a KV @ 100C of 13.32, making it a light 40.
Mobil 1 5w50 does carry VW 505.00, which surprises me. That would actually mean it's okay to run in my car (needs 502/505).
Mobil 1 0w40 is a really well built oil.
This is my first choice.
Remember that thinner oils cool better. They run about 10 deg less. You may also get better race results from less drag and more oomph!
You've ruled out the Mobil 1 10w-40 HM?
Wait, I see your climate is cold.
Mobil 1 5w30 HM HT/HS is 3.4cP
Maybe you could get away with the 10w30 HM, higher HT/HS, 3.68cP,iirc.
