Castrol Edge in 0W-20 & 5W-20
OK, so we have CE that tailors to US makes, we have CE that tailors to Asian makes. When will we have CE that tailors to zee German makes? I'm feeling left out...
CE have a 0w30 on their UK website but it has a VI IIRC of only 169. Heck that's lower than the orginal green GC!
I guess you're saying they don't make a 0W-40 yet but I'm sure they must?
Originally Posted By: CATERHAM
Castrol Edge's 5W-20 has a very decent VI as well at 175 which is higher than any other OTC 5W-20.
But since it has a lower 100C vis at 8.34 cSt vs 8.85 cSt for the 0W-20 grade it better be cheaper and/or a lot more shear resistant otherwise it is a redundant product made for marketing purposes only.
Agree on that.
Buster, slightly off topic but when are you posting the used oil analysis of the Red Line 0W-20 you've been running?
I haven't take a sample yet. Probably in the next week or so. 10,000 miles of every extreme condition.
Originally Posted By: Patman
Those 40c and 100c specs sound just like the Toyota 0w20! Interesting! I love the idea of more 0w20s becoming available, and would love to see one come out with an even lower 40c viscosity. I wonder if it would be possible to see one with a 40c viscosity of 30-35cst? (while still having a 100c viscosity of around 8 to 8.5)
Back in Dec' byez posted a 8,000 km used oil analysis on the Toyota 0W-20 from a Tundra. The 100C vis had sheared to 8.0cSt.
I don't think we will see 40C vis spec's down in the 30-35cSt range anytime soon and still maintain a 8.0cSt plus 100C spec.
It would have been interesting to have seen the 40C vis in the byez used oil analysis. If the oil maintained it's 214 VI then theoretically the 40C vis would have been under 35cSt. But that's not what happens usually when an oil shears as the VI usually drops.
rcy, said he was going to have his Toyota used oil analysis done shortly by Wearcheck and as you know they perform both 40C and 100C vis tests so we'll get one example of what happens to Toyota's VI in service.
If this oil is in fact loaded with Moly like the Honda and Toyota oils are, it is a score. Hopefully AAP will stock it, and it becomes part of their OC specials with a Pure One filter would be fine! As always seeing UOA would be nice, they are just around the corner for the Toyota oil. Knowing this group an Castrol EDGE 0W20 VOA is on its way. JMO
Originally Posted By: Bruce T
I suspect it's not yet available in North America.
Probably sooner rather than later we will see it given the increasing use of 0W20 in new car engines in NAmercia.
Sure, there is CE 0w-40, just not sold in the US.
What I'm saying is there is no CE in the US that meets any of the European mfg specs. I'll stick with GC for now.
A Google search on "Castrol Edge 0W-20" only shows Japanese references. I suspect it's not yet available in North America.
That being the case, CE 5W-20 vis' spec's are almost identical to Pennzoil Platinum 0w20 with a similar low 40C vis' of 42.6cSt and high VI. Technically it appears to have an "edge" over all 5W-20's and many 0W-20 currently available if you want a 20wt with a low start-up viscosity.
The 0w-20 is listed on the American Castrol website. I'm sure it will show up on the shelves pretty soon.
Originally Posted By: lonestar
I think this one looks pretty good.
Viscosity @ 100°C, cSt (ASTM D-445) 9.0
Viscosity @ 40°C, cSt (ASTM D-445) 49.1
Viscosity Index (ASTM D-2270) 165
VISC. CCS, cP (ASTM D-5293) 4069 (-35)
Flash Point °C (°F) (COC) (ASTM D-92) 228 (442)
Fire Point °C (°F) (COC) (ASTM D-92) 246 (475)
Pour Point °C (°F) (ASTM D-97) -54 (-65)
NOACK (% weight loss) (ASTM D-5800) 8.6
Total Base Number 12.1
High Temperature/High Shear Viscosity
(ASTM D-4683 @ 150°C, 1.0 X 106 s.-1), cP 2.8
That's Amsoil ASM I think. The 40C number for the Toyota oil is better, my guess is Edge will be better too.
