Castrol 5W-20 in Toyota Highlander 9 000 km
Russia
This is my 6th UOA from 0 to 59600 km in Toyota Highlander. You can see all results of different lubricants in one table. First OCI's shows big number of wear metalls and Si, but it is usual situation for new Toyota engine 2GR-FE. The lowest wear was with TGMO 0W-20 (lowest viscosity among oil oils) in summer period))). VOA of Castrol is here http://www.bobistheoilguy.com/forums/ubb...al_#Post3253660
Code:
Oils: 1-Factory fill oil 5W-30
      2-TGMO 5W-40 SM
      3-LUKOIL LUXE 5W-40 SN
      4-TGMO 0W30 SL/CF
      5-TGMO 0W-20 SN
      6-Castrol Magnatec Professional E 5W-20
            1        2          3          4          5          6
Km on oil   8 000    9 600     10 600      9 000     11 400       9 000
Km on Unit__8 000   19 700     30 200     39 200     50 600      59 600
KV100       9,03    11,86      11,78      10,1        7,91        8.23
KV40       58,6     72,34      69,27      55,72      38,99       43.67
VI        132      160         167       171        180         166
Ca       2222     2352        2571      3044       2272        1910
Mg         13       12          18        11         11          10
Zn       1022      913        1173       996        812         805
P         876      752         983       884        730         720
B          0       160          43        10          3           1
Mo         87        0           4         0         90          36
Sn          0        0           0         0          0           0
Pb          1        1           0         0          0
Cu       332        98           9         7          3           3
Fe        45         5*         20        16         11          19
Cr         1         0           0         1          0           1
Al        21         7           4         8          4          11
Si       243        65          25        19         16          16
Na         1         6           3         2          3           6
K          0         1           0         1          1           0
TBN        3,51      5,02        5,24      5,38       3,27        3,16
TAN        2,69      3,57        3,3       3,86       2,65        2,88
*- lab mistake IMO
avss1
Russia
Originally Posted By: Danno
I would stick with TGMO 0W-20. Seems to work really well with your engine.
I agree. Now I am om 5W-30 ACEA A5/B5 full SAPS oil but next OCI will be on 0W-20. I will try another 0W-20 from the market, may be Mobil or Idemitsu.
avss1
Russia
Originally Posted By: DemoFly
I'm surprised the TBN is still so high after 5600 miles.
TBN retention of all oils in my engine
Code:
oil                   OCI,km         TBN fresh oil             TBN Used oil
                                ASTM D 2896    ASTM D4739       ASTM D4739
Toyota FF 5W-30       8 000         NA            6.36 (1)         3.51
TGMO 5W-40            9 600        10.2           NA               5.02
LUKOIL LUXE 5W-40    10 600         9.94          8.54             5.24
TGMO 0W-30            9 000        10.1           9.0              5.38
TGMO 0W-20           11 400         8.02          NA               3.27
Castrol 5W-20         9 000         8.83          6.48             3.16
all numbers were tested, (1) - FF oil - sample from the engine after 200 km 2GR-FE is a good engine. It does not kill oil)))
