Carquest Premium (Blue) 84356 Cut Open
North Carolina
Second oil change on the new Odyssey at 4,500 miles. Well built filter. Still catching glitter.
Looks excellent. Topic is very similar to if not the same as the Bosch Prem 3323 and P1 PL14610 I've recently used on Hondas, Nissan and c&p. No worries with these on adbv slits because of proper design, i.e. central part doesn't rest on inlet holes.
Thanks for serious c&p.
The CQ (Purolator/Mann) Blues are OK, but AAP wants a pretty penny for them-$10.99 regular price, might be able to get under $9 with a code. Too much for what you're getting (IMO).
Not with Speedperks. I use my personal account with my work card to get the Perks so all 4 filters were F R E E
CQ filters are also available with the oil change deals, which lowers the price of the oil + filter to pretty good price.
That’s true, I’ve picked up a couple CQ HD (Baldwin made) ones that way. I need to find more ways to make work buy stuff there…
Looks perfect rooflessvw... Perfect.
I almost have wondered if the Wix filter media has started going into these CQ premium oil filters. .
Saw another thread on here and the Purolator Pureone blue can filter had filter media that looked a whole whole lot like Wix filter media.
Hope you are doing good wildman.
....I popped on a CQ Premium 85334.....
So you're going 'rogue' and using the older Honda (pre ~01-02) spec application filter. Obviously, no width restriction issues on the Odyssey for the wider application. Starting 08, on many Hondas (e.g. Accord), restriction won't permit use of wider application. Fwiw, I too would rather use it than waste it.
M&H using a variant of the Wix filter numbering system for the Puro made CQ.
