The smoke has been really thick here the past couple of days as well.
I took a plastic tool box and cut a hole in it and installed a high flow 140 mm computer fan on it. I then put a 4 inch elbow out the back and hooked it up to my basement dryer vent with another elbow and hooked it into a humidifier control module and it is really exhausting the smoke from the house and acts a dehumidifier as it is pulling the damp air from the bottom of the floor.
Of course I set it to where it won't shut off, super low humidity.
Saves my other exhaust fans and actually is doing a decent job for not much money.
If anyone wants a picture I will oblige .. I even have a brick on the top to keep the tool box secured and sealed.. desperate measures![]()
Seeing >350 AQI right now.NY/NJ airports have been on and off during the day, flights delayed.
NYC briefly registered as the worst air quality in the world today.
I am only 40 miles from PhillyThis says Philly is going to get it hard tomorrow. Www.firesmoke.ca
We have two air purifiers, and a 16x25x4 MERV 14+ charcoal filter in the central HVAC unit AND I am still going to do this for the furthest rooms.I feel for you guys and can affirm I understand what you are experiencing having gone through it for the last few years in California.
The most cost effective solution Ive found is a cheap box fan, and a MERV 13 or better filter taped to the intake side of the fan. If you can get a 13+ charcoal get it.
As you'd imagine the thicker you get it, the more airflow you will have. We settled on the 4" thick filters.
If you can only get 1" thick units build a V for more airflow with cardboard sealing the top and the floor usually seals the bottom. You can go as far as making a cube, and it will flow more, but the filters will likely be hard to get right now and be at a premium.
We had AQI of 450 in the building and had 50 of these going they dropped it down fast to something we could live with in a short time.
There have been extensive studies of the effectiveness of these setups and they are every bit as effective and often more than much more expensive dedicated units.
Looks like I'm in the light blue area.Here is rain map for the last 7 days. You can change number of days and zoom in here: https://water.weather.gov/precip/
We got about 3/4 inch last night - but from the maps it was a very localized thunder storm. I would say coastal SC is about normal YTD, or at least I haven't had to water my lawn much and its nice and green.
If you click on historical data to the left - or just click here: https://www.weather.gov/wrh/climateLooks like I'm in the light blue area.
