+1What's the "reason"?
The engine management accounts for cold starting and warmup. I assume we are discussing the engine performance.
Would changing oil temperatures cause a problem with the cam timing?
Are you starting a hot motor every morning? Cold oil is thicker oil.
Stop using logic !Does anyone think owning and operating a car in a frigid climate, with constant severe cold starts, is harder on electronic cam phasers? And if so, are they more prone to cam phaser trouble? I would imagine so, if they're as oil viscosity critical as they say.
That being said, there is only just so much tolerance they can design into these systems. I know Chrysler says to use ONLY 5W-20 oil in their 5.7 HEMI V-8 because of this. Using anything thicker can cause it to throw codes. But like "930.engineering" says, you don't start a hot vehicle every morning. So what are we to believe?
What's harder on electronic cam phasers? Living in Miami in June, with 10W-40 in the crankcase. Or living in Fargo in January with 5W-20?
CAFE MPG credits.There's a reason 5w-20 is recommended. Why second guess it?
without a doubt, yes.So.... Is it safe to say extended oil changes are more of a threat to electronic cam phasers, than heavier viscosity oils are?
Why?without a doubt, yes.
sludge and carbon buildup are definitely far more likely to obstruct the passages in a cam phaser or solenoid than a thick (but clean) oil is. i would have thought that to be self-evident.Why?
Properly extended oil changes do not cause sludge or carbon build up.sludge and carbon buildup are definitely far more likely to obstruct the passages in a cam phaser or solenoid than a thick (but clean) oil is. i would have thought that to be self-evident.
however, improperly extended changes do. and even following a previously known-good extended oil change regimen can result in unwanted buildup if there is a significant change in driving style and/or conditions. the question was, "is it safe to say extended oil changes are more of a threat to electronic cam phasers, than heavier viscosity oils are?" and there absolutely is more potential risk to such components from running oil for too long, than there is from running an oil that is too thick.Properly extended oil changes do not cause sludge or carbon build up.
That’s quite a difference in oil pressure. Engine temperature and oil pressure are two of the main criteria the ECU monitors when variably changing the cam phasing. It’s possible your caravan has a wider margin of error but many vehicles will alter engine tuning if there is a difference in oil pressure.I ran 0w40 in our Grand Caravan. Couldn’t tell any difference except it maintained 40psi of oil pressure while cruising according to the EVIC instead of 30 it normally did on 5w20.
A proper extended lubricant change has enough margin to allow for "change in driving style and/or conditions". What you are really talking about is lack of maintenance - "running oil for too long"however, improperly extended changes do. and even following a previously known-good extended oil change regimen can result in unwanted buildup if there is a significant change in driving style and/or conditions. the question was, "is it safe to say extended oil changes are more of a threat to electronic cam phasers, than heavier viscosity oils are?" and there absolutely is more potential risk to such components from running oil for too long, than there is from running an oil that is too thick.
The 3.6 Pentastar uses a variable displacement oil pump which may have something to do with it. Cruising or gently accelerating it’s in “low” mode, around 3,000-3,500rpm it goes full blast and will kick out 80psi+, when it’s cold it’s also in “high” mode.That’s quite a difference in oil pressure. Engine temperature and oil pressure are two of the main criteria the ECU monitors when variably changing the cam phasing. It’s possible your caravan has a wider margin of error but many vehicles will alter engine tuning if there is a difference in oil pressure.
