"I believe a good Dino PCMO like Chevron/Texaco or Pennzoil could go 7500 ml OCI in a Buick 3800 or 2.3L Saab with very little problem."
Oh my God! Someone who doesn't automatically parrot the "Dino can't last more than 5,000 miles" line? How can it be? This is heresy!!!
Amazing but true, here's a Chevy Lumina that went 7,200 mi on Rotella dino with iron, copper, and lead wear of 18, 9, and 5 ppm, respectively. Somehow, against all BITOG logic, the engine just refused to grenade! Report: "Wear matals stayed reasonable so we don't think the oil use interval was too long."
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000766
A Toyota Tacoma at 7,300 mi on Castrol GTX dino with 4 Fe, 2 Cu, and 4 Pb ppm, respectively. Report: "At present, your engine appears to be doing very well running these miles."
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001528
A Honda Accord at 6,900 on Castrol GTX dino with 6 Fe, 2 Cu, and 5 Pb, respectively. Report: "Wear read normally..."
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001594
A Buick Century at 6,700 mi on PetroCanada dino with 15 Fe, 15 Cu, and 12 Pb, respectively. "All component wear rates are normal...There is no indication of any contamination in the component."
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001412
I won't comment on insolubles/sludge/varnish/TBN issues, as I didn't investigate that far. I only glanced at the wear numbers (all of 'em great, and all under 20 ppm), but will say that debate over the I/S/V/TBN issues mentioned is fully legitimate, as wear numbers are only one part of the big picture.
That said..."7,500 miles on dino? The sky will fall...Civilization will end!!!" NOPE. Ain't gonna happen accordingly to the few high-mileage drain UOAs I came across (thanks to T-Stick for two of the UOAs). Some engines would suffer from 7,500 mi changes, no doubt about it. And I prefer to change at about 5-5,500 mi simply because I feel more comfortable with it and I get my dino for all of about 50 cents/qt after promotions. But blanket statements such as "Dino won't last past 5,000 mi" are just lame wive's tales that repeatedly get parroted without real evidence to back 'em up. Exactly how is 4-18 ppm iron wear over ~7,000 miles a problem?
[ June 22, 2004, 08:14 PM: Message edited by: TC ]
