Let's say you are considering a new vehicle and the base engine option is a 2.4L, 4-cyl turbocharged direct-injection engine that performs adequately but is somewhat noisy and unrefined.
Due to current market conditions and differences in trim level packages, you have the option of getting a 2.5L, 4-cyl Hybrid Powertrain, but for an additional $3500. During the test drive, you find the hybrid powertrain to be significantly quieter and smoother under normal driving conditions.
Both engine options deliver nearly-identical 0-60, 1/4 mile and passing performance. Both engine options also require premium fuel.
The hybrid delivers 10 mpg better than the non-hybrid option, but as a low mileage driver, the fuel savings are non-existent should a battery replacement be required within 15 years of ownership.
Therefore, opting for the hybrid in this situation is strictly for the upgraded driving experience. Does it makes sense to do it?
