The points that I am trying to make are that the hybrid doesn't NEED or require premium, it won't hurt anything by running 87 octane, and even if the engine management system can give you more ignition advance using premium, the benefits (if any) will not come anywhere close overcoming the price difference. If it gives you the "warm and fuzzies" by running premium in it, then by all means run it and pay the difference.Not sure if I agree with that one until I do some data-logging to validate. Even in an Atkinson Cycle engine, there is potentially room within the calibration to take advantage of the higher octane. The knock retard can be monitored and graphed with scan tools to validate your argument.
If we end up with the hybrid, I'll put this on my long-term to-do list.
Back to the MPG difference. Everyone that I have talked to who owns a turbocharged engine vehicle does not get the rated MPG in the city. Some people get close to it and some people get FAR worse. In the case for hybrids, most people that I have talked to get right at the rated MPG and some get even better. Case in point, a buddy of mine purchased a new Highlander hybrid AWD last September and he has tracked his MPG from day 1. He has consistently gotten 35 mpg, right at the EPA MPG rating, and he doesn't drive like a grandma. The RX is rated 1 MPG higher. He also tried premium in it because his owner's manual said that it would get better gas mileage when using it. It didn't, so he went back to 87 octane. Most of the people with the 2.4L Turbo engine are reporting around 20 to 21 MPG in the city, but some are only getting 16 to 17 MPG. Nobody that I have talked to is getting 24 MPG in the city. This is typical of turbocharged engine vehicles.
Something else to consider, the battery pack is improved from earlier hybrids. Also, it is now mounted INSIDE the vehicle under the 2nd row seat where it gets cooler interior air, and it has active cooling fans. Furthermore, the battery is far easier to repair/replace in it's current location. Toyota has also learned a LOT about how to keep the battery deterioration down and has incorporated changes in the hybrid system computer algorithm to accomplish this. I believe that the battery life concerns have become a non-issue.
