UPDATE: I want to start by thanking this community and everyone who shared their ideas and knowledge with me.
Many suggested I scrap, sell, or change the car's engine. However, I was keen on gaining firsthand experience in dealing with sludge issues, fully aware that I might eventually need to replace the engine. As the saying goes, "The more you F around, the more you find out," right?
I tried to use BG Dynamic Engine Cleaner & Rinse Oil due to its proven results. Unfortunately, residing in Toronto, I found only one distributor, and despite multiple attempts, I couldn't even reach them. Purchasing online wasn't viable either, as shipping chemicals to Canada is restricted, and Amazon listed it at around $450. Considering I found a shop willing to replace the engine for $800 in labor, spending $450 wasn't economically sensible.
I was actually really excited to remove the valve cover and share the results, measure cam journals clearances and pictures when i removed the valve cover after running a quarter bottle of Sea Foam with Mobil 0W40 for 5,000 km. The plan was to, changed the oil filter every 2,500 km, anticipating that a clogged filter would trigger the bypass, rendering it ineffective. I did this once and the filter accumulated sludge, prompting me to adjust my plan to change the filter every 1,000 km.
Tragically, a drunk driver hit my parked car, resulting in a total loss. After all that effort, it feels like a part of me left with the car.
Consequently, I can't inspect the cam journals or share further findings. I know that my aggressive approach might have caused more harm than good, but you gotta f around to find out!
For others facing similar issues, here are some insights from my experience:
- Oil Pressure Increase: I observed a 2 PSI rise in oil pressure.
- Engine Performance: Despite frequent redlining and reaching speeds over 180 km/h, daily driven and a heavy foot, the engine performed flawlessly. no oil pressure issues
- Oil Pump Inspection: I went down the rabbit hole researching the code indicating low oil pressure before startup. Research suggested possible wear-induced gaps in the oil pump. Although I inspected the pump, I neglected to use a feeler gauge to check impeller clearances—a significant oversight.
- Sea Foam Usage: While some caution that Sea Foam might alter oil properties or dislodge large sludge chunks into oil passages, I didn't experience definitive negative results. Given that oil pressure can exceed 40 PSI (over 58 PSI at 6,000 RPM in my engine), it's plausible that sludge could traverse oil passages and eventually settle in the oil pan or filter.
- Oil Squirters Concern: I feared buildup in the tiny oil squirters. However, considering the pressure in those passages, it's likely sufficient to dislodge or break up sludge. In my case, some sludge resembled hardened layerslike something you would experience when scarping layers of paint off a wall, but crumbled under pressure.
- High RPM Driving: If you're dealing with sludge and don't have issues like failing piston rings or valve stem seals Etc., driving at high RPMs to achieve higher oil pressure might help. Additionally, adding Sea Foam seemed to improve oil pressure, which surprised me, as I anticipated it might thin the oil. Perhaps Sea Foam genuinely delivers on its promises.
- Final Thoughts: I wish I could further inspect the valve cover, but circumstances prevent that. Please consider my experience as anecdotal; your mileage may vary.
Thank you! PS: Yes,Chatgpt did refine this message. It was way longer lol
