- Joined
- Nov 27, 2024
- Messages
- 9
So I bought a BMW 535 and everything seemed good until I opened the valve cover. I was experiencing lower than average oil pressure. I'm getting about 24 to 26 at idle. Just bearly within spec.
Buy most people are getting around 35 psi at idle.
I dropped the oil pan. Replaced the plastic oil pickup tube. There was a few plastic peices from the old timing chain in the oil pick up tube...
I changed the rod bearings while I was there too.
But that didn't really improve the oil pressure. Opened the head due to vanos codes and seen this mess...
My question is should I use something like BG engine cleaner. As I seen it helped increase the oil pressure. Or some other engine flush. I tired shorter OCI around 1000kms.
