Bosch Platinim +4 after 101k miles
quote:
what's "reverse firing"?
Its a term used when referring to DIS ignition systems. Half the plugs get fired in reverse. This is why you want a double platinum plug that has platinum on the side AND the center electrode. If you use regular platinum plugs that only have a platinum on the center electrode then half the plugs will wear out faster.
quote:
Originally posted by kenw: what's "reverse firing"?
also know as a waste spark or dump spark. Newer Jeeps have this same feature, and same problem with single tip platinum plugs. A little more explanation is that you have 1 coil for 2 plugs, and the coil fires both plugs at the same time, one on compression cycle and ignights the fuel, one on exhaust (so no fuel to burn in cylinder)
quote:
Originally posted by Whimsey: How does the spark know which electrode to go to? [I dont know] . Whimsey
The electrode with the least resistance will fire first,Im sure the resistance will change during firing.
since the camry these plugs came from (3.0L v6, 1997) has 1 coil servicing 2 plugs, I would guess that makes it "waste spark" by Tom's and blupupher's definitions. The coil packs are mounted on the front bank and the secondary plug wire feeds the 3 backside plugs. thanx for the help.
quote:
[LOL!]
quote:
No, the above explanation is "how it works." The "explanation" I was laughing at makes no sense.
