I was recently talked into inspecting a co-worker’s 2008 528i. One of his complaints was that the front-end felt a bit loose. Once the car was on the rack, I noticed that the tension strut bushings (some people call them upper control arm bushings or thrust-arm bushings) were moderately torn.
The car has 183k, so the finding was not completely surprising.
One option is to replace just the bushing since the ball joint appears to be OK. The hydraulic bushings are $100 from the dealer and it will be another $10-$15 for the required new hardware. I do have access to a shop press, but I have no experience with pressing bushings. Plus, I am not sure that the shop has the right adapters.
Another option is to replace the two tension struts with a new set from the BMW value line. BMW sells a kit that includes two new arms and all of the required hardware for about $315. While this is certainly the easy route, $200 seems like a steep amount to pay for new arms and ball joints that may not be necessary.
My co-worker only plans to keep the car for another 2 years. With that in mind, I’d like to save him some money – but I also do not want to put myself in a bad situation (i.e. unable to return car in the promised timeframe, or accidentally fubar the arms while pressuing the bushings out). Then again, even if we go with new arms, I’ll still be saving him $300 compared to having it done at an indy BMW shop.
What do you folks suggest – new bushings only, or new arms?
Thanks
