wolfestone
Are you talking about the plastic baffle at the top? If so, some red coating up there is normal - there just isn't enough oil splash there to wash it off, but condensation frequently occurs resulting in discoloration, regardless of what oil is used.
Yes, the same as the underside of the oil filler cap appears. Thanks for the info.
I've been looking over these UOAs:
Shanneba's BMW UOAs
and while I'm far from knowledgeable on this subject, it appears to me that there wasn't a clear/consistent 'best' between them. Some appeared to have more additive left at the end, and it didn't seem that any one significantly reduced a particular wear metal.
Is that a fair assumption? I'm sure there's far more involved in interpreting the data than I can imagine.
I'm hesitant to go with the gold GC just because the green was reportedly excellent, and the BMW 5w30 at least seems to be a known entity.
Shanneba's BMW UOAs
