I realize there's been a million "what oil should I put in my bmw" threads, but I have a slightly different set of questions I wasn't able to answer by searching alone.
I own an e46 (m54 motor), with 65k miles on it. It's been in the florida climate since new. The car is using about 1 quart of oil every 1400 miles, which has gradually worsened over the last 25k.
Before I owned this car, it had an oil change at 15k, then at 32k and 37k, with BMW/castrol 5w30 oil. I have changed the oil every 5k miles since with BMW/castrol 5w30.
Now, here's my question: I am about to replace this car with a new 328i (n52 motor). This will be the first car I've bought new, and I want to keep it a long time without running into the same oil consumption issues I have now. It appears the oil is burning off, and is getting past the rings. I'm aware this is within what bmw deems 'normal'.
It's been recommended to me that I switch to a 10w40 oil due to the hot climate. I've questioned this with one synthetic oil supplier who advised against it.
What I really want is to make an educated guess as to whether the oil consumption issues on my current car were more likely caused by the long OCI for the first 30k miles, by the bmw/castrol 5w30 not being ideal for this hot climate, or by something else entirely.
As of now, I'm looking at either the BMW LL04 oil (5w30?), redline 5w30, redline 5w40, or redline 10w40.
I've been comparing the viscostity @100f ratings, and see the BMW 5w30 is thicker at temperature than redline 5w30.
The scenario I'm worried about is that I pick the wrong oil, and even with regular changes end up again in a few years with a car that uses a lot of oil.
I would really appreciate any advice on how to best select an oil that will fit my needs the best. Cost is less of a factor than the best wear protection.
