The car is 1995 Toyota Tercel with manual door/fuel/trunk locks. Prior winter I sprayed the key holes with WD-40. After one winter heavy rain with freezing temp overnight I was not able to open the trunk because the lock was frozen next morning. When the weather got warmer, I tried the white lithium grease from a can and sprayed a lot into the key holes. After another freezing rain the trunk lock frozed again. Although I never have problems unlocking the driver side door. Will thick grease in the key holes work?
