Low-temperature lube for sticky trunk lock mechanism
twX
Canada
My trunk latch mechanism stopped latching closed last winter in cold temperatures (below -5C or so). It would latch properly after heating it up with a blow drier. I sprayed some lube into it (I believe WD40 first, then some white lithium grease). Eventually it started working properly, but this may have been partly due to the warming weather. So far this winter it has worked down to -20C, until today when it got stuck in more mild conditions.
Anyway, I'd like to know what the best lube would be to try, before I replace the latch with a new one. I'd like to use something that is good in low temperatures (down to -35C) and available in a spray.
I use WD40 and Lucas Tool Box Buddy spray on mine. My buddy likes the Houdini brand spray for his trunk and tailgate. If winter gives it issues maybe get some Lock De-Icer it comes in a spray can too and is like a lubricant. I use the sprays listed above year round and they don’t give me any issues ever.
WD-40 is not an oil. It has a very thin solvent in it to carry the chemicals that will protect metal from rusting even after the solvent evaporates. But the solvent may provide some temporary lubrication for a week or two before it evaporates. And the solvent may flush out dirt. But the chemicals that are left behind to protect metal from corrosion may actually hinder parts from moving once the solvent is gone.
look at WD-40 Specialist® Gel Lube, also called ‘Spray & Stay Gel Lubricant’
It claims to have a very wide temp range.
I bought it for my door latch - also concerned about winter operation. Thus far I am impressed with it. Gel really sticks. Interestingly, it is a rattle can.
I use garage door lube now. I've tried a lot of specialty lubes; most are redundant with other things, and there are a simply ridiculous number of specialty lubes on the market now. This kills a lot of needs in one can.
Basically it's a gussied-up silicone spray lube, but it sticks and doesn't attract dust. Great for a lot of uses. Other sprays can work as well.
https://www.lowes.com/pd/3-IN-ONE-11-oz-Garage-Door-Lube/3348342
What’s the latch assembly made of nylon, metal, mix of both do you have an electric trunk release? Clean the mechanism with rubbing alcohol in a spray bottle unless you find brake kleen to not harm the mechanism. Then blow it out with compressed air.. I’d use a dry lube or graphite. You can also spray rubber trunk seals with silicone spray on a rag keep the rag in your trunk and when you do use the trunk wipe the seals before closing so any moisture won’t freeze up between the trunk and rubber seals
You can use a lite fingers coating of white grease also... may be better for use if the latch is nylon...
The lock mechanism is a power lock in a plastic housing, like this. I don't think I'll use brake cleaner. The mechanism is mostly enclosed. I don't think I'll use brake cleaner to clean it out. Maybe compressed air and then a silicone lube. I can't imagine there is water in the latch that has frozen up but I might spray some lock antifreeze in there first.
Good idea skip the brake kleen use compressed air or rubbing alcohol to break down any grime and gunk. A silicone grease sounds like your best choice
I would be concerned that the gel lube, like a grease , would hold metal chips.
With time and wear, jamb up the lock.
