Quote:
the very best even better (i believe) then zaino is finish kare products and also griot's garage products which they make some of zaino's products for zaino..
Griot's Garage does not make any products for Zaino.
Quote:
for those for whom only the the high priced stuff will do!
Click for definitive auto wax/sealer test
http://www.consumerreports.org/cro/cu-pr...Term=auto%20wax
Quote:
Quick question... can paint sealant be applied over multi-time waxed surfaces???
Or, must you clay bar or dawn-detergent-wash your surfaces first, in order to strip the wax?
Thanks!
JMH
Quote:
mshu7 wrote
“Hard to beat the Klasse twins. While they seem expensive, a bottle will last you quite a while b/c you don't need much for application.
http://www.autogeek.net/klasse.html
BTW, AutoGeek.net is having a 15% off sale right now. Use SMARTSHOPPER2 as the coupon code.”
The “SMARTSHOPPER2” coupon code does not work are there any others?
Thanks.
To get a great rating in Consumer Reports all you need is $. Plus the "test" was very limited it appears.
Quote:
for those for whom only the the high priced stuff will do!![]()
Quote:
If you dont like CR's reports, than ignore them. But dont cry about their reports not being valid. Would that be true, they would have been shut down long ago via countless law suits from deep pocket companies. They can defend themselve VERY well in court, time and time again. That can only be done with unprecidented documentation and proceedures followed.
