Well, there you go. Oil entering the combustion chambers, if that's getting by the rings (the typical mechanism) than a heavier oil would typically reduce the consumption, as the previous poster claimed.
What makes pao so special?Thanks… Just throwing in my personal experience. Expected feedback to be brutal. Going from 5w-20 to 5w-30 makes a difference in oil consumption? I am surprised that Mobil 1 5w-30 does not have PAO, learned something there…
It is not balanced and needs POE to counter the seal shrinkage.What makes pao so special?
The darkness is, likely, primarily the result of the DI. DI engines produce soot, which makes the oil dark. That's not reflective of the condition of the lubricant however.
It has dual injection now, both DI and port:Is the F150 5.0L engine DI?
For some reason I thought it was NA when I was researching (2015-16 timeframe) and a very good engine. That's before I decided to go with Tundra.
In 2018, Ford switched from the more traditional cast iron sleeves in the block to the Plasma Wire Arc Transfer cylinder liner technology. This increased the bore diameter from 92.2 to 93.0 mm (3.63 to 3.66 in) and brought up total displacement from 4,951 to 5,035 cc (302 to 307 cu in). The Gen 3 Coyote engine features dual-fuel, high-pressure direct injection with low-pressure port fuel injection and an increased compression ratio of 12.0:1. These changes are relevant to both the Mustang GT and F150 with 5.0 V8s.
For the 2018 Mustang GT, the Gen3 5.0 engine also was equipped with new camshafts, enlarged intake and exhaust valves, and a revised intake manifold, that moved redline to 7,500 rpm.
Yep… gotta be perfect and nothing is.one shrinks, one expands, requires a perfect mixture ...
GRP III looks better & better.
Our local Ford dealer sells Mobil 1. That's likely the simplest explanation.
Notice the recommended oil in these service bulletins… Every situation is unique. Why Mobil 1 5w-30 would fix the problem?
If you worked at a Ford dealer would you use what they gave you to use?
Group III is definitely less of a formulation challenge, that's one of the reasons it is so popular. It is also significantly less expensive. Nothing touches PAO in cold temp performance though, and POE has phenomenal oxidation resistance. Mix that with AN's to get even better solubility and reduce surface competition (an artifact of POE polarity) and you end up with a very potent combo. But, it's a lot more expensive and likely of very little advantage to Average Joe unless he's in Winnipeg or Fort Mac.one shrinks, one expands, requires a perfect mixture ...
Still with the high profile issue with the service bulletins it would be wise to follow the TSB. If you read the last two they are changing out the engine.Our local Ford dealer sells Mobil 1. That's likely the simplest explanation.
Sure, but if a dealer can avoid doing a warranty claim for an engine just by changing the oil, clearly, that's the route they are going to go. Warranty work doesn't pay well and doing a longblock swap is a huge PITA.Still with the high profile issue with the service bulletins it would be wise to follow the TSB. If you read the last two they are changing out the engine.
I'm not sure how that counters the point I was making about warranty claims, can you elaborate?Everyone works for someone or some company… Come on. Ford superseded their own TSB but kept on saying what oil to use.
Think the engine replacement is when oil consumption is found to be from cylinder wall damage. From @OVERKILL link on the Coyote:Still with the high profile issue with the service bulletins it would be wise to follow the TSB. If you read the last two they are changing out the engine.
What do you want to know? What you think is reality or the reality of working for Ford?I'm not sure how that counters the point I was making about warranty claims, can you elaborate?
I'm not sure if that's rhetorical or not? My friend owns the FCA dealership I deal with. I have several good friends that are dealer mechanics as well as knowing two service managers extremely well. I am very well acquainted with how dealerships work on warranty work and what avenues are pursued before embarking on longblock replacement as well as the manufacturer's requirements for allowing such a claim to proceed.What do you want to know? What you think is reality or the reality of working for Ford?
