If the above is working for you I wouldn’t change a thing. Now If you could get valvoline or castrol for less those are fine alternatives.Best oil for 2020 5.0L Coyote F150 engine? 62,xxx miles.
Occasional towing of 5 - 7 thousand pounds.
Have been running Mobil 1 with Motocraft filter.
Thanks so much.
5w30 Mobil 1. As a former ford tech when thr 5.0 would come in for oil consumption issues which was common, we used 5w30 and it stopped it. Also for 2021 model year, ford switched from 5w20 to 5w30. Just a food for thought.I would keep using the 5w-20 Mobil 1 and a Fram Ultra filter. About any 5w-20 synthetic should work. The Motocraft filter should be fine too. Keep it clean is the best way to make the engine last a long time.
Interesting. What was the oil prior to Mobil 1?5w30 Mobil 1. As a former ford tech when thr 5.0 would come in for oil consumption issues which was common, we used 5w30 and it stopped it. Also for 2021 model year, ford switched from 5w20 to 5w30. Just a food for thought.
Food for thought… sounds like a seal issue. Mobil 1 changed the problem but now you are locked in on that oil and if you change back the oil problem will return. Sounds like any oil with the words “High Mileage” would fix the problem. But for the average Joe without oil consumption problems it may be that 5w30 Mobil 1 might not be a good choice if you want to return to other oil brands. My personal experience was when I used Mobil 1 for the last OCI that did not leak. I gave the 2008 Miata to my neighbor to my neighbor and he used something else and the car started to leak. Coincidence maybe… but it is part of the equation of PAO/POE base oils.5w30 Mobil 1. As a former ford tech when thr 5.0 would come in for oil consumption issues which was common, we used 5w30 and it stopped it. Also for 2021 model year, ford switched from 5w20 to 5w30. Just a food for thought.
No it doesn't.Food for thought… sounds like a seal issue.
That's ludicrous.Mobil 1 changed the problem but now you are locked in on that oil and if you change back the oil problem will return.
He said the 5w30 fixed the problem, did you read his post? He's saying that as a Ford tech, when trucks running 5w-20 would come in with consumption issues, they'd put the heavier 5w30 Mobil 1 in them, and the consumption would stop.Sounds like any oil with the words “High Mileage” would fix the problem. But for the average Joe without oil consumption problems it may be that 5w30 Mobil 1 might not be a good choice if you want to return to other oil brands.
He never mentioned a leak.My personal experience was when I used Mobil 1 for the last OCI that did not leak. I gave the 2008 Miata to my neighbor to my neighbor and he used something else and the car started to leak.
The current brew of Mobil 1 5w30 has no PAO in it.Bill_W said:Coincidence maybe… but it is part of the equation of PAO/POE base oils.
The darkness is, likely, primarily the result of the DI. DI engines produce soot, which makes the oil dark. That's not reflective of the condition of the lubricant however.i have an 18, 5.0. in my experience it is hard on oil, even after 5k miles the oil comes out very dark. between the high compression ratio, direct injection and 4 cams with 32 lifters. The oil is being abused a fair amount the only saving grace is the capacity, its holds 9 quarts with the composite oil pan.
Thanks… Just throwing in my personal experience. Expected feedback to be brutal. Going from 5w-20 to 5w30 makes a difference in oil consumption? I am surprised that Mobil 1 5w30 does not have PAO, learned something there…No it doesn't.
That's ludicrous.
Seal compatibility is seal compatibility, all oils have to be within the same range as defined by the API and ACEA.
I had Mobil 1 5w30 about 20 years ago, trigger a valve cover gasket leak on my 5.0L. That engine had cork VCG's, they were ROCK hard, and not as a result of the Mobil 1, just as a result of being original from 1987 and being exposed for almost two decades of heat cycling. The Tri-Syn formula (PAO/AN/POE) was capable of some mild cleaning and once the deposits that were preventing those VCG's from leaking were removed, the flood gates opened. I replaced them with the silicone ones sold for the Explorer and it was bone dry again.Thanks… Just throwing in my personal experience. Expected feedback to be brutal.
Ewww, will have to see if I can find one. I have the MSDS from 2015 handy, which shows 20-30% PAO. I'm sure I've got a more recent one here somewhere, give me a few.What was the formulation of Mobil 1 in 2019 when it was SN, just curious?
October, 2021 is apparently the next one I have here. Ugh. Could check my other computer.Ewww, will have to see if I can find one. I have the MSDS from 2015 handy, which shows 20-30% PAO. I'm sure I've got a more recent one here somewhere, give me a few.
