best oil for 402 stroker motor?
midland tx
excuse the lowercase, my hand is broken. the shop that built the motor recomended using only conventional oil, no syn. they suggested rotella 15-40 for the break in and then 2 oil changes after that bc of the good additive pack it has. i was thinking valvoline vr1 10-30. what do you guys think?
You could use Rotella Syn 5W40 after the first oil change-it's a stout oil. Mobil 1 0W40 is another good choice.
The shop does not recommend syn oil because they want to sell you an engine sooner.;)
Break in on conventional then use whatever oil you want. VR-1 is conventional oil correct? If it was me I would run a syn oil regardless of what the shop said.
I agree 100% the shop builds engines and not oil.
I would run synthetic also from the start.
A 402 GM, Ford, Pontiac, Buick, Olds, Honda?
does it have a roller cam or flat tappet camshaft?
If you dont know for certain then I dont know what to tell you.
many many people buy built engines but really dont know how to maintain them.
Amsoil makes a 10w40 oil that is a High Performance oil with the proper additives for flat tappet engines.
I use this oil in my 351W with a solid lift cam and it works very well.
I will not change this oil for the life of the engine from previous experiences with this oil.
I have a 1966 Corvette with a totally rebuilt 427 L72 425 HP, a vintage 1966 block cast Feb 1966 ..engine was bored ,030 over /block decked in 1994 . have installed comp cam extreme energy hyd flat tappet cam 4 years ago & endlebrock alum heads 7 years ago.do my own mechanical work ....ocasionally run the 1/4 mile oldies day at new england dragway best et 13.3 @ 105 MPH ....... RPM is limited ( by me ) to 5700 RPM . broke engine in on conventional 10w30 conventionalsore oil , then Moble one 4 quarts 10/30 & two quarts 15 /40 ..6 total , when i did cam broke cam in with conventional oil & then went to moble one again... so my story is since 1995 synthetic oil no problems , good pump ability i driove my Corvette hard approx 2,000 miles a season & moble one has worked for me ....no leaking or or burning
'' Semper Fi ''
Show me a 402 Honda and I'll eat a head gasket with no ketchup.
It's two punched Honda V6. One on the front and one on the back.
Sorta like a Citation with a Fiero back end.
Ok I have a caterpillar copper head gasket no ketchup coming right up!
