Assume the oil pump moves 8 GPM with an output pressure of 75 PSI. Calculate the required HP into the pump.
The required HP to move 8 GPM at 75 PSI with filter A and a 85% efficient oil pump = 0.41 HP.
The required HP to move 8 GPM at 80 PSI with filter B (with 5 PSI more delta-p) and a 85% efficient oil pump = 0.44 HP.
The change in HP due to the more restrictive oil filter is +0.03 HP ... which is 22.4 watts. That's like 4 night lights ... basically nothing worth even focusing on.
