I would be very surprised if this was indeed true.quote:
All Kwik Trip gas in the US has at least 8% ethanol in it. 8% ethanol is required to be labeled "Top Tier Gasoline"
In Wisconsin, the rules for pump labeling of ethanol are quite strict, as we have a portion of the state using the EPA mandated reformulated gas with ethanol, and the majority of the state is regular gasoline.
Both Shell & Kwik Trip are Top Tier gas and are supplied from the Conoco Phillips wood River refinery in southern Illinois. I do not see the ethanol label on pumps in the regular gas portion of the state.
As we have discussed in previous threads, a top tier gasoline must pass the detergent test with the worst case scenario, ie, a formulation with 8% ethanol.
If the detergent additive passes the test in an 8% ethanol blend, it will also pass with a regular gasoline formulation.
