comparing mobil drive clean with castrol gtx and penzoil..which one is better?? 10w-30 mobil drive clean user.
It would be best to test in you motor,your driving styles then decide imo you skeptic youquote:
But if the oil you chose on a new car is doing it's job right, that engine should still be within factory specs even after 100k, so the need for a thicker oil shouldn't be there at all.quote:
Originally posted by Bror Jace:
Pablo, that's what I do, essentially. I wouldn't use an oil that thick in a newer car, but once the thing has 100,000 miles on the clock, it's probably a good choice for many vehicles, weather permitting.
--- Bror Jace
